Hi
I cannot find how to connect Alexa and my robot vacuum, Both of them are connected to HA and work fine.
Any suggestion what kind of intent to use ?
I create alexa skill and can ask “Alexa, ask Miia to {action}” [start/stop/return_to_base]
but nee to create intent in HA to handle passed action. Can some one help me ??
Not sure if you ever got this working. I got mine set up. I had to use a switch template for Alexa to use.
switches:
vacuum:
value_template: "{{ is_state( 'vacuum.robovac', 'on') }}"
turn_on:
service: vacuum.turn_on
entity_id: vacuum.robovac
turn_off:
service: vacuum.return_to_base
I did a write-up as well if you want more detail. https://smarthomehobby.com/2018/03/21/the-xiaomi-robot-vacuum-home-assistant-and-alexa/
this work very good, thanks for sharing.
I just do not understand how/where to put the script
Add “script.find_vacuum” to the rest of your Alexa accessible entities.
I am not sure if i want to use it but i am curious about how it works.
Regards
