How to use an entity with dot in his name?
My media player has dot in his name (media_player.2dcgyqlkw6f6e)
So this config that are working for other media players in my network get me back an errot for the dot…
{% if is_state('media_player.2dcgyqlkw6f6e','playing') %}
   {{ media_player.2dcgyqlkw6f6e.attributes["media_title"] }}
{% else %}
   Inattivo
{% endif %}
How I can solve?
I must be missing something. I don’t see a dot in that media player’s name.
Isn’t your template missing a period after attributes?
It isn’t the ‘.’ that is the problem, it is the number 2 as the leading character.
In your template use
states.media_player['2dcgyqlkw6f6e'].attributes
instead
I’m not sure if you’d have to do the same for the is_state(), since I typically just access things directly with an else fall back case.
EDIT: you were also missing the leading “states” since that has to be there in front of media_player unless you are passing it into a function which prepends it.
Try this for your template:
{{ states.media_player.2dcgyqlkw6f6e.attributes.media_title}}
OMG! You’re right @Dolores… why I have focused on dot? every entity has a dot! :thinking:
Yes… the problem was the starting digit.
The solution came from @nordlead2005… thanks!
