How to use an incoming email as a trigger for an alert
Hi.
I am trying to set up an alert/notification that is triggered by an incoming email. This could be from a specific email address or simply whenever any email is received. I have successfully installed the IMAP integration but I can not figure out how to get it to fire a trigger using it. Does anyone have any suggestion on how to achieve this?
Thank you!
There are examples at the bottom of the documentation page (scroll down): IMAP - Home Assistant
Screenshot 2023-12-24 at 12-47-54 IMAP
Hi @tom_l ! Thank you for this. I did try it and so far can not get it to work.
Here is what I have done so far. Note that the only thing I changed in the below example is the email address. Should something else be edited for my case? I am not very fluent with HA so I am sure I am missing something obvious.
description: TEST
  - platform: event
    event_type: imap_content
    event_data:
      sender: [email protected]
condition: []
  - service: notify.notify
      message: TEST
      title: TEST
mode: single
Thank you!
Check the automation trace:
I did not make any other changes except rebooting HA but it suddenly started working! Thanks so much!
Hi @tom_l . Sorry but one last question. How can I make it alert if I receive ANY email, not from a specific one but literally any? I tried * and that did not seem to work. Any suggestion? Thank you!
Leave out the event_data
What am i doing wrong here?!?! I am getting the below error when trying to make this template sensor and it doesn’t appear to be working, I have never used these before.
