Aqara Hub gateway gen 1
Aqara Hub M1S (ZHWG15LM)
Product name:Aqara Gateway M1S
Product model: ZHWG15LM
Internal model:lumi.gateway.acn001
The M1S gateway supports Aqara brand‘s ZigBee 3.0 and earlier ZigBee 1.2 devices.
Mi Home app |
yes |
Aqara Home app |
yes |
|Apple Home app|yes|
Way 1: Mi Home mode (paired with mi home app)
Product model:ZHWG15LM. (China model)
internal model :lumi.gateway.acn001
Firmware version:4.0.2_0006,4.0.3_0012
Integration: homekit controller.
or
https://github.com/al-one/hass-xiaomi-miot use this integration
or
GitHub - niceboygithub/AqaraGateway: Aqara Gateway/Hub integration for Home Assistant use this integration
DEVICES = [{
'lumi.gateway.acn01': ["Aqara", "Gateway M1S", "ZHWG15LM"], # tested
source:https://github.com/niceboygithub/AqaraGateway/blob/ed60497eaa61e549c35d68be7768ac1326cf59b6/custom_components/aqara_gateway/core/utils.py#L32
After the 2021 M1S gateway has been upgraded to the latest version 4.0.2_0006 firmware in the Mijia APP, as long as the Aqara gateway plugin is loading and connected to the M1S gateway, the M1S gateway will be abnormally offline immediately, and it can only be restored after power off and restart.
[2020版M1S网关在米家APP升级了最新版4.0.2_0006固件后,Aqara gateway只要一连接网关就会造成网关立即异常离线,只能断电重启才恢复。 · Issue #120 · niceboygithub/AqaraGateway · GitHub]
Way 2:aqara home mode (paired with aqara home app)
Aqara Hub M1S Gen 1
Firmware: 3.5.2, 4.0.1_0022.0642(20230512 updated)
app: Aqara Home app
region: china in Aqara app.
Other
Product model:HM1S-G01. (US model)
internal model :
Firmware version:4.0.2_0012.0644 2023-05-22 4.0.2_0024.0644(2023-06-07)
2023-05-22,Firmware 4.0.2 (Beta) adds support for Matter
source:https://www.aqara.com/us/version/hub-m1s
1.You need to select the China region in the Mi home APP settings to use;
2.This Aqara gateway can work with Mi Home App, Apple Homekit and Aqara Home App.
3.Switching the platform will restore the gateway to factory settings. The network, automation and sub-devices need to be reconnected and set up;
4.Mijia and Aqara Home APP cannot be connected at the same time, only Mijia APP+HomeKit or Aqara Home can be used at the same time APP+HomeKit
