Largus72
(Largus72)
March 28, 2023, 8:37pm
1
I’m trying to make a custom sensor template that looks like a threshold with use of two attributes with valuies from input numbers. But somehow the sensor results in unavailable.
- template:
- sensor:
- name: Sensor_Name
unique_id: sensor_name
state: >
{% if states('sensor.somesensor')|float < states('this.attributes.min_value')|float %}
below
{% elif states('sensor.somesensor')|float > states('this.attributes.max_value')|float %}
above
{% else %}
within
{% endif %}
attributes:
min_value: "{{ states('input_number._min_value') | float }}"
max_value: "{{ states('input_number._max_value') | float }}"
How can I make this work?
The this
variable already contains the state object of the sensor, so you cannot use the states()
function on it… and, due to load order, you will likely need to set a default as well.
- template:
- sensor:
- name: Sensor_Name
state: >
{% if states('sensor.somesensor') | float < this.attributes.min_value | default( ? ) %}
below
{% elif states('sensor.somesensor') | float > this.attributes.max_value | default( ? ) %}
above
{% else %}
within
{% endif %}
attributes:
I know this is just an example, but just in case… the object id of an entity (like your input numbers) shouldn’t start with a punctuation or number.
Largus72
(Largus72)
March 29, 2023, 3:13pm
3
Hi Drew,
Thanks for your help.
Created a sensor to keep track of bitcoin going under or above a certain level:
- template:
- sensor:
- name: Bitcoin drempelwaarde
unique_id: bitcoin_drempelwaarde
state: >
{% if states('sensor.cryptoinfo_crypto_bitcoin_eur') | float < this.attributes.min_value | default( 15001 ) %}
onder drempelwaarde
{% elif states('sensor.cryptoinfo_crypto_bitcoin_eur') | float > this.attributes.max_value | default( 25001 ) %}
boven drempelwaarde
{% else %}
binnen drempelwaarde
{% endif %}
attributes:
min_value: "{{ states('input_number.btc_min_value') | float }}"
max_value: "{{ states('input_number.btc_max_value') | float }}"
cur_value: "{{ states('sensor.cryptoinfo_crypto_bitcoin_eur') | float }}"
Works great now!
