Hello community, I’m trying to create a “stuck open” alert and it’s mostly there. I thought I had it working and could swear that it was prior to the latest 2021.4.X update but maybe I was imagining things. I’m trying to use the until
clause to exit the automation when the open door is eventually closed but that doesn’t seem to work.
Now, when it runs if a door or garage door is open when the sun sets and stays open for a while, the speakers start telling us: “Alert. XYZ door is/are stuck open at night” which is good. Then we go and close the door and it should at that point change the group state to “off” and exit the automation but it doesn’t. After another interval, the speaker comes on and just says: “Alert.”! What the heck?? Is my logic backward or something?
- id: sonos_stuck_open_alert
initial_state: true
alias: Sonos Stuck Open Alert
mode: parallel
value_template: "{{ is_state('group.all_exterior_doors', 'on') and is_state('sun.sun', 'below_horizon') }}"
for: "{{ states('input_datetime.sonos_stuck_warning_interval') }}"
value_template: "{{ is_state('group.all_garage_doors', 'on') and is_state('sun.sun', 'below_horizon') }}"
- alias: Repeat until the door is closed
repeat:
sequence:
- service: script.all_sonos_say
volume_level: 0.8
message: >
Alert.
{% if is_state('group.all_exterior_doors', 'on') %}
{%- for entity in states.group.all_exterior_doors.attributes.entity_id if is_state(entity, 'on') %}
{%- if loop.first and loop.last %}
{{ states[entity.split('.')[0]][entity.split('.')[1]].name }} is stuck open at night
{% else %}
{%- if loop.first %}{% elif loop.last %} & {% else %}, {% endif -%}
{{ states[entity.split('.')[0]][entity.split('.')[1]].name }}{{ " are stuck open at night" if loop.last }}
{%- endif -%}
{% endfor %}
{% elif is_state('group.all_garage_doors', 'open') %}
{%- for entity in states.group.all_garage_doors.attributes.entity_id if is_state(entity, 'open') %}
{% else %}
{%- endif -%}
{% endfor %}
{% endif %}
- delay: "{{ states('input_datetime.sonos_stuck_warning_interval') }}"
until:
- condition: template
value_template: >
{{ is_state('group.all_garage_doors', 'off') and is_state('group.all_exterior_doors', 'off') }}
I think I’m going to have to use the new feature for debugging the automations when I get a chance to do so. That might help shed some light on it but I’m guessing the logic in my until
template equation is to blame.
