Good morning, Europe! Good night, America!
Is there any chance to connect an HomeAssistant Installation to a KNX-Powerline-System using this USB interface 6133 from Busch-Jaeger Electrics?
Any hints welcome!
CU
Peter
Any hints welcome!
CU
Peter
Hi !
Maybe with a Knx Usb to IP bridge software (Calimero or knxd).
But I’d highly recommend to get a proper Knx IP Interface (Gira or Weinzierl are known to work great). These would connect to TP, not PL though. Is your installation pure PL?
Hi, Matthias!
I own and use an IP-KNX-Gateway from Weinzierl and the eibPort from BAB-TEC which’s one leg stands in the IP-Environment, while the other one keeps contact to the PL-World. But now I want to connect my home assistant directly to the Powerline using this USB-Interface 6133 from Busch-Jaeger.
Next idea?! Please!
May I ask why?
You have a perfectly fine and supported interface. Just use that. HAs Knx driver only supports Knx-Ip, not USB.
You may … … I still have a massive number of PowerLine-Sensors which can not be replaced that easily due to the wife-factor …
And why can’t you use those with an IP interface? Don’t you have a PL-TP coupler?
If have a Weinzierl for TP to IP, I have an eibPort for IP to PL … so some kind of domino … I also have a way from TP to PL and back. but I haven’t got a clue how to ask the devices to route those packets
