I’m currently a bit lost. I’m moving from fhem where I was using this Busware CC1101 USB stick without any problems. I’m now trying to get this running with hass.io. What’s my best option to get my HomeMatic devices (not HM-IP) working in hass.io?
It looks like the stick is not supported by the HomeMatic CCU add-on. Unfortunately I’m not able to use the HM-MOD-RPI-PCB (the slot is already blocked). Is there an alternative?
In your opinion: What’s my best/easiest option to get my HomeMatic devices working on hass.io?
Have a look at Homegear. IIRC there is a Homegear addon available somewhere, but I’m not sure how well this works. If it’s an option, install Homegear on a dedicated machine with the CUL attached. With that in place the HomeMatic integration should work for you.
Could you explain how you did this?
I could pull the docker image an start it. But is could not mount folders from outside of the image “mkdir” says “mkdir: can’t create directory ‘test’: Read-only file system” if I am connected via ssh. How did you start the container in boot?
