Hi
It seems like I need a cluster command:
endpoint id: 11
cluster id: 8
command: 1
when I want to implement smooth dimming.
This command has 2 arguments:
move_mode up/down and
rate: 0-255.
I am able to execute this cluster command under manage zigbee device → clusters → commands.
The light is doing what it should, it starts with smooth dimming.
Now I want to use this in an automation. The yaml looks like this:
alias: Bathroom Ceiling Light Dimming
description: Bathroom Ceiling Light Dimming
- device_id: $id_of_remote
domain: zha
platform: device
type: remote_button_long_press
subtype: dim_up
condition: []
- action: zha.issue_zigbee_cluster_command
metadata: {}
cluster_type: out
ieee: 01:23:45:67:89:12:34:56
endpoint_id: 11
cluster_id: 8
command: 1
command_type: client
args:
- 0
- 50
mode: single
When I press the button on the remote for a long time the script is executed but the bulb doesn’t react. I’m new to home assistant and a little bit lost now.
How can I debug this issue?
Is there another way for smooth dimming? Increasing the brightness in 10% steps in a loop doesn’t look good.
Thank you very much.
