I’m creating a custom card using the HA documentation here : https://developers.home-assistant.io/docs/frontend/custom-ui/lovelace-custom-card/
Then I try to apply on div / span custom classes which are defined in a custom CSS file imported via the Locelace Board.
I checked that CSS file is loaded, it is.
Example :
<span class="blink">${stateSensorStr}</span>
CSS :
.blink {
background: red;
Does someone had this issue ?
