I need to publish parameters received on Serial on a Tasmota device to MQTT.
Currently I do as below and works ok:
rule1
ON SerialReceived#Param1 DO publish stat/tasmota_123/RESULT {“Param1”:%value%} ENDON
ON SerialReceived#Param2 DO publish stat/tasmota_123/RESULT {“Param2”:%value%} ENDON
ON SerialReceived#Param3 DO publish stat/tasmota_123/RESULT {“Param3”:%value%} ENDON
Where input data on serial is as:
{Param1,57}
Syntax is {ParameterName:ParameterValue}
But my problem is that I have too many parameters that would not fit in rule maximum space (1000 chars) and actually ParameterX can be any text as MyCutomText, so I would receive something like:
{MyCustomText,57}
{AnotherCustomText,123}
{ThisCanBeAnything, 45}
And there is no space to write all the rules for all possible values of parameter names.
I need some wildcard as below, but don’t know how to pass parameter name as value:
ON SerialReceived#? DO publish stat/tasmota_123/RESULT {%data%:%value%} ENDON
%data% in this case should be the value of ParameterName
while %value% works ok as value of ParameterData
Does anyone have some idea how to achieve this?
