Hey folks,
I’m stepping my way through understanding templating, and I’m trying to use the below to achieve
When humidity is greater than 55%, switch on fan, and when it’s less than 55% switch off fan. Can anyone suggest what daft mistake I’m making in the below?
value_template: >-
{% if state('sensor.main_bathroom_humidity') | float > 55 %}true{% endif
id: Above 55% Humidity
value_template: >-
{% if state('sensor.main_bathroom_humidity') | float < 55 %}true{% endif
id: Below 55% Humidity
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: switch.turn_on
data: {}
entity_id: switch.main_bathroom_fan
- conditions:
sequence:
- service: switch.turn_off
data: {}
You’ve just got a couple little issues…
There is no reason to use an if statement for your examples.
The function is states() not state()
You need to provide a default value for many filters, including float.
value_template: >-
{{ states('sensor.main_bathroom_humidity') | float(0) > 55 }}
value_template: >-
{{ states('sensor.main_bathroom_humidity') | float(0) < 55 }}
However, it’s not really necessary to use template triggers here, since the basic Numeric state trigger will work fine… And that will also allow you to easily add a for variable so your fan doesn’t bounce on and off if the humidity is hovering around your setpoint.
- platform: numeric_state
entity_id: sensor.main_bathroom_humidity
above: 55
for: "00:01:00"
below: 55
for: "00:01:00"
condition: []
- service: switch.turn_{{ trigger.id }}
I appreciate you taking the time to lay out the syntaxical issues with my initial approach, and then suggesting the simpler approach with the for variable - this has really helped my learning. Thanks Drew
murph
June 28, 2025, 3:10am
4
Hi, im just new trying to learn as I go. Can anyone help with what I have here please.
alias: Guest Ensuite Auto Fan on
description: ""
triggers:
- entity_id:
- sensor.aqara_thermostat_03_humidity
above: 65
for:
hours: 0
minutes: 1
seconds: 0
trigger: numeric_state
- entity_id:
below: 65
for:
hours: 0
minutes: 5
seconds: 0
conditions: []
actions:
- target:
entity_id: switch.smart_switch_24080518624019510701c4e7ae07d5f3_outlet
action: switch.turn_{{ trigger.id }}
There’s nothing wrong with your automation, you’ll need to explain what issues you are having.
It’s likely a misunderstanding about how triggers work .
FWIW, a better solution for this might be a Generic Hygrostat Helper .
murph
June 28, 2025, 3:28am
6
Yes, the automation did not turn off the fan as expected after the 5 min below 65% humidity
Ok, thanks I’ll read up on triggers, the Generic Hygrostat looks like a good option also. , I appreciate your help.
