How to use hall flowmeter for detecting hose burst
Hi there, I’m new to HA and this is my first request for a little help from you.
I would like to use my hall flowmeter for detecting a hose burst in my irrigation system. The flow meter works well and shows met the current liters per hour. What can I do best to test if the flow is below or above some levels for a period and then use it to shut off my water pump and send me a notification? For now I make use of some simple automations in my irrigation system.
Thanks in advance
Harryf
Hi Harry,
I used ESPHome with a NodeMCU to achieve what you are looking for. Here is the ESPHome config. Not sure it is the best or only way of doing things but it appears to work.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxxxxxxxxxx"
  password: "xxxxxxxxxxxxxxxxxx"
  ap:
    ssid: "Potager Watering"
    password: "xxxxxxxxxxxxxx"
  manual_ip:
    static_ip: xxxxxxxxxxxxxxxxx
    gateway: xxxxxxxxxxxxxxxxx
    subnet: 255.255.255.0
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
web_server:
ota:
globals:
  - id: leak_boolean
    type: int
    restore_value: false
    initial_value: '0'
  - id: pulses_watering_start
    type: int
    initial_value: '0'
switch:
  - platform: gpio
    pin: D7
    restore_mode: ALWAYS_OFF
    inverted: true
    on_turn_on:
      # Initialse global with number of pulses when tap is turned on
      - globals.set:
          value: !lambda |-
            return id(total_pulses).state;
    on_turn_off:
      - wait_until:
          sensor.in_range:
            below: 1
      - sensor.template.publish:
          state: !lambda 'return id(total_pulses).state - id(pulses_watering_start) ;'
      - homeassistant.event:
          event: esphome.potager_watering
# Flow Meter
  - platform: pulse_counter
    name: "Potager Tap Pulses Per Minute"
    pin: D5
    update_interval: 20s
    internal: false
    on_value:
      then:
      # Above 800 pulses per minute
        - if:
            condition:
              sensor.in_range:
                above: 800
            then:
              - if:
                  condition:
                    lambda: 'return id(leak_boolean) == 1;'
                  then:
      # This is the 2nd time in a row that threshold has been exceeded so take action
                    - switch.turn_off: relay
                    - globals.set:
                        value: '0'
                  else:
                    - globals.set:
                        value: '1'
            else:
      # Reset leak boolean
              - globals.set:
                  value: '0'
    total:
      name: 'Potager Tap Total Pulses'
# Soil Moisture Sensor
  - platform: adc
    pin: A0
    name: Potager Soil Moisture Value
    accuracy_decimals: 1
    update_interval: 60s
    icon: mdi:flower
# Number Of Pulses This Watering
    name: Potager Tap Pulses This Watering
Hi there Glyn,
Thanks for sharing your esphome config. I didn’t realize that testing on the esp board it self is also an option. I will studie your config and see if I can use it in my setup. Have you thought about testing the leak detection in HA?
Best regards Harry
I decided to test on the board in case there was a communications problem or if HA was down.
