So, probably a newbie question here and I feel like this has probably been answered somewhere but lots of googling has turned up nothing. I have a script where I’m trying to populate a dictionary-type variable based on a select-type helper using the values of some number-type helpers. In the template editor in developer tools, I have this working perfectly:
{% if mode == "cool" %}
{% set setpoints = {'occupied' : states('input_number.hvac_default_temp_occupied_cool'),
'empty' : states('input_number.hvac_default_temp_empty_cool'),
'overnight' : states('input_number.hvac_default_temp_overnight_cool') } %}
{% elif mode == "heat" %}
{% set setpoints = {'occupied' : states('input_number.hvac_default_temp_occupied_heat'),
'empty' : states('input_number.hvac_default_temp_empty_heat'),
'overnight' : states('input_number.hvac_default_temp_overnight_heat') } %}
{% endif %}
Eventually, what I want to be able to do is the following:
service: input_number.set_value
entity_id: input_number.hvac_bedroom_setpoint
value: "{{ setpoints['occupied'] }}"
My big question is where to put the first block in the actual script - I keep getting errors any time I try to put that in variables
, but I don’t know where else it would go. Thanks for any help!
