I wonder how to use input number in an above condition?
Int the following code the problematic line is line 22 (if i hardcode the value it is working)
20 switches:
19 ga_heating:
18 # if one of the furnes is on. We are ON
17 value_template: "{{ (is_state('binary_sensor.ga_kazan_chpump', 'on') or is_state('switch.ga_kazan_relay_4', 'on') ) }}"
16 turn_on:
15 - if:
14 #- alias: "none of the kazan on"
13 - condition: and
12 conditions:
11 - condition: state
10 entity_id: binary_sensor.ga_kazan_chpump
9 state: "off"
8 - condition: state
7 entity_id: switch.ga_kazan_relay_4
6 state: "off"
5 then:
4 - if:
3 - alias: "temperature is more then input_number.kazan_on_temperature"
2 condition: numeric_state
1 entity_id: sensor.ga_kazan_temperature_4_pump_furnace
22 above: "{{ states('input_number.kazan_on_temperature') | float }}"
1 then:
2 - alias: "turn on the furnece"
3 service: switch.turn_on
4 target:
5 entity_id: switch.ga_kazan_relay_4
6 else:
7 - alias: "turn on the GAS furnece"
8 service: switch.turn_on
9 target:
10 entity_id: switch.ga_kazan_relay_1
11 turn_off:
12 service: switch.turn_off
13 target:
14 entity_id: switch.ga_kazan_relay_1
i am getting a following error message:
Invalid config for [switch.template]: expected float for dictionary value @ data['switches']['ga_heating']['turn_on'][0]['then'][0]['if'][0]['above']. Got "{{ states('input_number.kazan_on_temperature') | float }}". (See ?, line ?).
I am wonder what i am doing wrong here?
Thank you
