I want to set the value of an input_text to a specific data field from a trigger event. What’s the proper syntax for this? One of my many iterations is below. I’ve been through hundreds of forum posts and the answer eludes me.
Thank you both for the assistance. The solution posted was one that I had come to myself, but when it wouldn’t work properly I began to question it. With confirmation of the correct syntax and the value still not being assigned correctly, I investigated further and found that generating an event from the developer page would assign a blank value to input_text.status, but actually generating the event from the device would assign the value correctly. It turns out my syntax when generating the event from the developer page was wrong, so I likely had it “working” early on, but I was too lazy to go physically generate an event and I couldn’t get out of my own way. All sorted now. Another lesson learned. Thank you.
