How to use "long press" or "double/triple push" for Enocean FT55 rocker?
Hi there,
I use some FT55 rocker in my house.
Today I got one test FT55 rocker working with HA. They are configured as binary_sensor and the enocean integration. Single push for the four buttons is very easy to use…
alias: Enocean - 01
description: ''
  - platform: event
    event_type: button_pressed
    event_data:
      id:
        - 0
        - 54
        - 4
        - 106
      pushed: 1
      which: 1
      onoff: 1
condition: []
  - service: notify.mobile_app_mbiphone
      message: FT55 - 01
mode: single
Is it possible to use “long press” or “double/triple push” with FT55? Some Ideas?
Any idea? Possible to work with a template?
I solved it via NodeRed and the Enocean-js plugin… you can flexibly cover everything with it.
Could you Share the Node Red Setup ?
Michael
Any HA based solution? :slight_smile:
