I have somehow specific problem to be solved related to automation of my blinds on harmony activity state change. Basically when I switch off any activity I use harmony remote state change to: PowerOff
to trigger opening the blinds. The problem is that when hassio is restarted harmony integration is also changing state from Unknown to PowerOff triggering unwanted opening of the blinds. I tried to filter out this situation by using not state_is
Unknown in condition, but it does not work - seems condition is checked after the trigger, so state is already PowerOff and it is not preventing automation to run. So seems solution it to use conditional from in trigger⌠but I have no clue how to make it, if possible at all. Here is my current code ( not working properly, as described above):
- alias: "Open blinds on turn off"
initial_state: true
platform: state
entity_id: sensor.tv_room_harmony_activity
to: 'PowerOff'
condition:
condition: template
value_template: >
{{ not is_state('sensor.tv_room_harmony_activity', 'Unknown') }}
- service: shell_command.blinds_up
What I need is something like (do not even know what notation would look like):
initial_state: true
platform: state
"Apple TV"
"Smart TV"
"Games"
"Cable TV"
to: 'PowerOff'
Is it possible? Could templates be used here somehow? Otherwise the solution would be to have 4 different automations for each scenarioâŚ
