I have HomeAssistant running on a Raspberry Pi in Virtual Environment. It is all running ok from LAN and from Internet so 192.168.1.2:8123
and mysite.duckdns.org:8123
work ok.
As I intend to run it behind an nginx webserver and because of ISP limitations, ports 80, 443 cannot be used so I have adopted this approach
and server config splitting as in
Certificates were generated successfully with
So I have configured it as http in port 8888 and https in port 8889. Of course, router port forwarding is configured as external 8888 to internal 8888 and external 8889 to internal 8889 in 192.168.1.2
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
# Update this line to be your domain
server_name mysite.duckdns.org;
# These shouldn't need to be changed
listen 8888;
return 301 https://$host$request_uri;
server {
ssl on;
ssl_certificate /home/pi/.acme.sh/mysite.duckdns.org/fullchain.cer;
ssl_certificate_key /home/pi/.acme.sh/mysite.duckdns.org/mysite.duckdns.org.key;
ssl_prefer_server_ciphers on;
listen 8889 http2; # if your nginx version is >= 1.9.5 you can also add the "http2" flag here
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_session_cache shared:SSL:10m;
access_log /var/log/nginx/hass.access.log;
error_log /var/log/nginx/hass.error.log;
proxy_buffering off;
location / {
proxy_pass http://localhost:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
Thank you for your input. I have tried both options.
Firstly, with return 301 https://$host$request_uri;
has resulted in already known ERROR_CONNECTION_TIMED_OUT message. May it be that $host is not storing any value? Or not storing? mysite.duckdns.org?
Secondly, with the long script: I have pasted it into a brand new default file (removed duplicate ssl on; and ssl_prefer_server_ciphers on; that resulted in error after testing default with sudo nginx -t
I have restarted nginx and http://mysite.duckdns.org:8888/ will produce the same ERROR_CONNECTION_TIMED_OUT message whereas https://mysite.duckdns.org:8889/ works ok and shows secure Home Assistant website.
Sorry I have not been successful. Thank you in advance for any input.
edit: I have even generated dhparams as described in Home Assistant NGINX webpage and added to server just below
