Can I simply plug the dongle into the same port used previously?
Or do I have to setup the Z2M configuration again?
Not sure what steps I have to do
It depends how you have your dongle setup in Z2M. If it’s by device ID, then should just work. If it’s by port, you’ll likely need to update it.
