benek984
(Benek984)
March 3, 2022, 10:06am
184
Below my .yaml config. Just add new device to EspHome paste this config and generate .bin
substitutions:
# Modify variables based on your settings
hostname: "esp32_power_monitor"
# this is just for ingormation where this device is located
#amend platford and board type
platform: ESP32
board: nodemcu-32s
esphome:
platform: $platform
board: $board
wifi:
ssid: !secret wifi_ssid
fast_connect: on
ap:
ssid: "AP $hostname"
password: !secret ap_fallback_password
captive_portal:
logger:
web_server:
api:
password: !secret ha_api_password
reboot_timeout: 5min
ota:
password: !secret ota_password
text_sensor:
- platform: version
- platform: wifi_info
ip_address:
ssid:
bssid:
binary_sensor:
- platform: status
time:
- platform: homeassistant
status_led:
pin: GPIO2
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
stop_bits: 1
- platform: wifi_signal
update_interval: 60s
- platform: uptime
- platform: pzemac
current:
voltage:
power:
state_class: measurement
frequency:
name: "Home Frequency"
power_factor:
name: "Home Power Factor"
update_interval: 5s
- platform: total_daily_energy
name: "Total Daily Energy"
unit_of_measurement: kWh
filters:
- multiply: 0.001
power_id: power
i2c:
sda: GPIO21
scl: GPIO22
scan: true
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
it.printf(0, 0, "* Home Power Meter *");
it.printf(0, 1, "Pow:%.0fW", id(power).state);
it.printf(10, 1, "Amp:%.1fA", id(cur).state);
it.printf(0, 2, "%.1fV", id(vol).state);
it.printf(14, 2, "%.1fHz", id(freq).state);
it.strftime(0, 3, "Time:%H:%M", id(esptime).now());
it.printf(10, 3, " WiFi%.0fdb", id(wifi_stat).state);
// first number shows position in line then comma and line number. 0 is first line
Gudiin
(Matheus )
March 4, 2022, 1:16pm
185
I have 2 pzem on the same modbus network
1 pzem = IP(1)
2 pzem = IP(2)
Part of the code used:
PinoTX:“GPIO12”
PinoRX:“GPIO14”
uart:
tx_pin: ${PinoTX}
rx_pin: ${PinoRX}
baud_rate: 9600
stop_bits: 1
switch:
platform: uart
name: “Phase 1 - Reset Energy”
date = [0x01, 0x42, 0x80, 0x11]
platform: uart
name: “Phase 2 - Reset Energy”
date = [?, 0x42, ?, ?]
What HEX numbers should I put to reset the power of the second pzem(IP=2)???
Here’s the reset commands for the first 15 addresses. I’ve tested up to 0x03.
Address
Command
0x01
0x02
0x02, 0x42, 0x80, 0xE1
0x03
0x03, 0x42, 0x81, 0x71
0x04
0x04, 0x42, 0x83, 0x41
0x05
0x05, 0x42, 0xAE, 0x1F
0x06
0x06, 0x42, 0x82, 0x21
0x07
0x07, 0x42, 0x83, 0xB1
0x08
0x08, 0x42, 0x86, 0x41
0x09
0x09, 0x42, 0x87, 0xD1
0x0A
0x0A, 0x42, 0x87, 0x21
0x0B
0x0B, 0x42, 0x86, 0xB1
0x0C
0x0C, 0x42, 0x84, 0x81
0x0D
0x0D, 0x42, 0x85, 0x11
0x0E
0x0E, 0x42, 0x85, 0xE1
0x0F
0x0F, 0x42, 0x84, 0x71
Edit: There were issues with 04 through 0F. Should be resolved.
potom
(Patrick)
March 13, 2022, 3:28pm
187
I thought it might be worth commenting on my experiences (thanks to this thread).
I have three PZEM v4, powered at 3v3 from a single Wemos D1 mini, using the diode multiplexing suggestion in this thread. It all works as it should - no components removed or mods to the PZEM units themselves required. I used a hybrid ESPHome config taken from this thread to program the Wemos. Many thanks to those who took the time to comment, I doubt I would have got there without!
pod
March 15, 2022, 10:03pm
188
I answer myself…
the circuit diagram is correct ant this code works.
only for V3!!!
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
level: debug
baud_rate: 0
# Enable Home Assistant API
api:
ota:
wifi:
ap:
ssid: "Powermeter Fallback Hotspot"
password: !secret wifi_password_fallback
captive_portal:
web_server:
port: 80
uart:
- id: ubus1
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
stop_bits: 1
#modbus:
# id: mbus
# uart_id: ubus
- platform: pzemac
# modbus_id: mbus
address: 1
current:
voltage:
energy:
power:
frequency:
name: "ID1 Frequency"
power_factor:
name: "ID1 Power Factor"
update_interval: 10s
- platform: pzemac
# modbus_id: mbus
address: 2
current:
voltage:
energy:
power:
frequency:
name: "ID2 Frequency"
power_factor:
name: "ID2 Power Factor"
- platform: pzemac
# modbus_id: mbus
address: 3
current:
voltage:
energy:
power:
frequency:
name: "ID3 Frequency"
power_factor:
name: "ID3 Power Factor"
button:
- platform: restart
name: Restart Powermeter
but the most important thing is to change the PZEM ID
to do it:
ESP flash with TASMOTA
connect PZEM
use this template
{"NAME":"HW-655 PZEM","GPIO":[0,62,0,98,6,5,0,0,0,0,0,0,0],"FLAG":0,"BASE":18}
via console use the command “ModuleAddress X” where X is the number of the ID to be associated with the PZEM (like this ModuleAddress 1, ModuleAddress 2, ModuleAddress 3, ModuleAddress x…)
done this build the circuit and everything works perfectly.
Hi bro, can you send me the circuit diagram for the circuit because I have a graduating project in the same subject, I will add indicators like buzzer and led when the energy reaches a specific limit, and also I will add the bill cost.
MarkB1
(Mark Booth)
March 17, 2022, 8:40am
190
I have copied my code below, and for what you are looking for I think could be done with ESPHome Automations, use spare GPIO as switch and use the values as sensors.
Also YES! All automations you define in ESPHome are executed on the ESP itself and will continue to work even if the WiFi network is down or the MQTT server is not reachable.
esphome:
platform: ESP8266
board: d1_mini
# esp8266_restore_from_flash: true
wifi:
ssid:
password:
power_save_mode: none
manual_ip:
static_ip: 192.168.0.103
gateway: 192.168.0.2
subnet: 255.255.255.0
dns1: 192.168.0.2
ap:
ssid: "Wemos D1 pZEM016"
password: "RSixraswZ4Vk"
captive_portal:
# Enable logging
logger:
level: DEBUG
baud_rate: 0
api:
ota:
# Enable Web server.
web_server:
port: 80
text_sensor:
- platform: version
name: "ESPHome Version PZEM 016"
# Example configuration entry
ip_address:
name: ESP IP Address PZEM-016
ssid:
name: ESP Connected PZEM-016
bssid:
#time:
# - platform: homeassistant
# id: homeassistant_time
time:
- platform: sntp
timezone: GB
uart:
rx_pin: GPIO3
tx_pin: GPIO1
baud_rate: 9600
stop_bits: 1
i2c:
sda: D2
scl: D1
# Fast sensors for Energy calculation & local display #
- platform: pzemac
current:
internal: true
voltage:
internal: true
power:
internal: true
frequency:
name: "PZEM-016 Frequency"
internal: true
power_factor:
name: "PZEM-016 Power Factor"
internal: true
update_interval: 2s
name: "PZEM-016 Daily Energy"
power_id: pzem_016_power
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
icon: mdi:counter
accuracy_decimals: 1
- platform: integration
name: "PZEM-016 Energy Meter"
sensor: pzem_016_power
time_unit: h
filters:
- multiply: 0.001
icon: mdi:counter
# Sensors with general information.
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
name: PZEM-016 WiFi Signal
# Slow sensors for Home assistant #
- platform: template #########################
name: "PZEM-016 Current Slow"
lambda: |-
if (id(pzem_016_current).state) {
return (id(pzem_016_current).state);
} else {
return 0;
unit_of_measurement: A
icon: "mdi:alpha-a-circle"
name: "PZEM-016 Voltage Slow"
lambda: |-
if (id(pzem_016_voltage).state) {
return (id(pzem_016_voltage).state);
} else {
return 0;
unit_of_measurement: V
icon: "mdi:alpha-v-circle"
name: "PZEM-016 Power Slow"
lambda: |-
if (id(pzem_016_power).state) {
return (id(pzem_016_power).state);
} else {
return 0;
unit_of_measurement: W
icon: "mdi:alpha-w-circle"
name: "PZEM-016 Frequency Slow"
lambda: |-
if (id(pzem_016_frequency).state) {
return (id(pzem_016_frequency).state);
} else {
return 0;
unit_of_measurement: Hz
icon: "mdi:alpha-f-circle"
name: "PZEM-016 Power Factor Slow"
lambda: |-
if (id(pf).state) {
return (id(pf).state);
} else {
return 0;
unit_of_measurement: PF
icon: "mdi:alpha-p-circle"
display:
dimensions: 16x2
address: 0x27
lambda: |-
it.printf(0, 0, "%.1fV", id(pzem_016_voltage).state);
it.printf(7, 0, "%.1f AMPS", id(pzem_016_current).state);
it.printf(0, 1, "%.1f HZ", id(pzem_016_frequency).state);
it.printf(8, 1, "P:%.1f W", id(pzem_016_power).state);
binary_sensor:
- platform: status
status_led:
pin:
number: D4
inverted: false
Regards,
can i add more than one pzem address in the same code that you have right?
pod
March 20, 2022, 9:16pm
192
what is the windows software you mention to change the pzem address?
better just use esphome
The (great) esphome docs tell you exactly how:
markss
(Mark)
April 10, 2022, 5:19am
194
Just wondering if the comment above "
Applies to configurations where there is only one PZEM004T?
I have mine setup but am not getting any power readings - I’ve checked all the connections so not sure what to troubleshoot next?
No, you only need to change the pzem004t addresses if you have more than one connected to one uart interface.
That’s very unfortunate but I can assure you nobody will be able to help you properly if you don’t provide logs.
markss
(Mark)
April 10, 2022, 10:37am
196
Yep, understood! Now that we have the first part out of the way.
EspHome YAML is:
esphome:
esp8266:
board: huzzah
# Enable logging
logger:
level: VERY_VERBOSE
baud_rate: 0
api:
ota:
wifi:
ap:
ssid: "Esphome-Web-48A0De"
password: "0jDkLK3czIY0"
captive_portal:
uart:
tx_pin: TX
rx_pin: RX
baud_rate: 9600
stop_bits: 1
debug:
modbus:
- platform: pzemac
address: 1
current:
name: "PZEM-004T V3 Current"
voltage:
name: "PZEM-004T V3 Voltage"
energy:
name: "PZEM-004T V3 Energy"
power:
name: "PZEM-004T V3 Power"
frequency:
name: "PZEM-004T V3 Frequency"
power_factor:
name: "PZEM-004T V3 Power Factor"
web_server:
port: 80
With logging turned on:
[20:35:16][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=145431 (now=155431)
[20:35:17][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:17][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:20][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:20][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:24][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=103609 (now=163609)
[20:35:26][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=155431 (now=165438)
[20:35:31][VV][scheduler:185]: Running interval 'update' with interval=60000 last_execution=110569 (now=170576)
[20:35:31][VV][uart.arduino_esp8266:180]: Flushing...
[20:35:31][V][modbus:184]: Modbus write: 01.04.00.00.00.0A.70.0D (8)
[20:35:31][D][uart_debug:114]: >>> 01:04:00:00:00:0A:70:0D
[20:35:32][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:32][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:35][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:35][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:36][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=165431 (now=175436)
[20:35:46][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=175431 (now=185435)
[20:35:47][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:47][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:50][VV][api.service:355]: on_ping_request: PingRequest {}
[20:35:50][VV][api.service:043]: send_ping_response: PingResponse {}
[20:35:56][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=185431 (now=195431)
[20:36:02][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:02][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:05][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:05][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:06][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=195431 (now=205436)
[20:36:16][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=205431 (now=215431)
[20:36:17][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:17][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:20][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:20][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:24][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=163609 (now=223609)
[20:36:26][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=215431 (now=225435)
[20:36:31][VV][scheduler:185]: Running interval 'update' with interval=60000 last_execution=170569 (now=230572)
[20:36:31][VV][uart.arduino_esp8266:180]: Flushing...
[20:36:31][V][modbus:184]: Modbus write: 01.04.00.00.00.0A.70.0D (8)
[20:36:31][D][uart_debug:114]: >>> 01:04:00:00:00:0A:70:0D
[20:36:32][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:32][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:35][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:35][VV][api.service:043]: send_ping_response: PingResponse {}
[20:36:36][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=225431 (now=235431)
[20:36:46][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=235431 (now=245431)
[20:36:47][VV][api.service:355]: on_ping_request: PingRequest {}
[20:36:47][VV][api.service:043]: send_ping_response: PingResponse {}
markss:
I don’t see much related to the pzem004t in the logs, could you set the mode logging to debug
(actually that’s less than very_verbose
which is set now) and also include the very beginning of the log to see if the component is set up successfully?
Just one thing comes to my mind, the pzem004t v1 and v2 (not sold anymore) need the pzem004t component in esphome. Only the pzem004t v3 (sold nowadays) is using the pzemac component.
markss
(Mark)
April 10, 2022, 1:39pm
198
orange-assistant:
pzemac
This is everything related to serial/uart/pzemac
[22:47:45][C][logger:233]: Logger:
[22:47:45][C][logger:234]: Level: VERY_VERBOSE
[22:47:45][C][logger:235]: Log Baud Rate: 0
[22:47:45][C][logger:236]: Hardware UART: UART0
[22:47:45][C][uart.arduino_esp8266:102]: UART Bus:
[22:47:45][C][uart.arduino_esp8266:103]: TX Pin: GPIO1
[22:47:45][C][uart.arduino_esp8266:104]: RX Pin: GPIO3
[22:47:45][C][uart.arduino_esp8266:106]: RX Buffer Size: 256
[22:47:45][C][uart.arduino_esp8266:108]: Baud Rate: 9600 baud
[22:47:45][C][uart.arduino_esp8266:109]: Data Bits: 8
[22:47:45][C][uart.arduino_esp8266:110]: Parity: NONE
[22:47:45][C][uart.arduino_esp8266:111]: Stop bits: 1
[22:47:45][C][uart.arduino_esp8266:113]: Using hardware serial interface.
[22:47:45][C][modbus:129]: Modbus:
[22:47:45][C][modbus:131]: Send Wait Time: 250 ms
[22:47:45][C][pzemac:067]: PZEMAC:
[22:47:45][C][pzemac:068]: Address: 0x01
[22:47:45][C][pzemac:069]: Voltage 'PZEM-004T V3 Voltage'
[22:47:45][C][pzemac:069]: Device Class: 'voltage'
[22:47:45][C][pzemac:069]: State Class: 'measurement'
[22:47:45][C][pzemac:069]: Unit of Measurement: 'V'
[22:47:45][C][pzemac:069]: Accuracy Decimals: 1
[22:47:45][C][pzemac:070]: Current 'PZEM-004T V3 Current'
[22:47:45][C][pzemac:070]: Device Class: 'current'
[22:47:45][C][pzemac:070]: State Class: 'measurement'
[22:47:45][C][pzemac:070]: Unit of Measurement: 'A'
[22:47:45][C][pzemac:070]: Accuracy Decimals: 3
[22:47:45][C][pzemac:071]: Power 'PZEM-004T V3 Power'
[22:47:45][C][pzemac:071]: Device Class: 'power'
[22:47:45][C][pzemac:071]: State Class: 'measurement'
[22:47:45][C][pzemac:071]: Unit of Measurement: 'W'
[22:47:45][C][pzemac:071]: Accuracy Decimals: 2
[22:47:45][C][pzemac:072]: Energy 'PZEM-004T V3 Energy'
[22:47:45][C][pzemac:072]: Device Class: 'energy'
[22:47:45][C][pzemac:072]: State Class: 'total_increasing'
[22:47:45][C][pzemac:072]: Unit of Measurement: 'Wh'
[22:47:45][C][pzemac:072]: Accuracy Decimals: 0
[22:47:45][C][pzemac:073]: Frequency 'PZEM-004T V3 Frequency'
[22:47:45][C][pzemac:073]: State Class: 'measurement'
[22:47:45][C][pzemac:073]: Unit of Measurement: 'Hz'
[22:47:45][C][pzemac:073]: Accuracy Decimals: 1
[22:47:45][C][pzemac:073]: Icon: 'mdi:current-ac'
[22:47:45][C][pzemac:074]: Power Factor 'PZEM-004T V3 Power Factor'
[22:47:45][C][pzemac:074]: Device Class: 'power_factor'
[22:47:45][C][pzemac:074]: State Class: 'measurement'
[22:47:45][C][pzemac:074]: Unit of Measurement: ''
[22:47:45][C][pzemac:074]: Accuracy Decimals: 2
That looks good so far. And what happens in the logs every 60 seconds when it should take measurements? Any errors?
Could anyone help me with this address change code? I have several questions regarding to this code.
What address does this code change the PZEM into?
I understand that the unchanged default address
from the factory is 1
. So does this change the address
to 2
Do I just copy and paste this exact code into the ESPHome YAML and it will change the address
to 2
What if I wanted to use 3 PZEMs and I need to change the address
to 3
abmantis:
It is also possible to set the PZEM address using ESPHome, with the following code:
esphome:
on_boot:
## configure controller settings at setup
## make sure priority is lower than setup_priority of modbus_controller
priority: -100
then:
- lambda: |-
auto new_address = 0x03;
if(new_address < 0x01 || new_address > 0xF7) // sanity check
ESP_LOGE("ModbusLambda", "Address needs to be between 0x01 and 0xF7");
return;
esphome::modbus_controller::ModbusController *controller = id(pzem);
auto set_addr_cmd = esphome::modbus_controller::ModbusCommandItem::create_write_single_command(
controller, 0x0002, new_address);
delay(200) ;
controller->queue_command(set_addr_cmd);
ESP_LOGI("ModbusLambda", "PZEM Addr set");
modbus:
send_wait_time: 200ms
modbus_controller:
- id: pzem
## the current device addr
address: 0x1
modbus_id: mod_bus_pzem
command_throttle: 0ms
setup_priority: -10
update_interval: 30s
I assume it has something to do with this?
markss
(Mark)
April 10, 2022, 9:59pm
201
This is all I get
[07:58:01][VV][api.service:355]: on_ping_request: PingRequest {}
[07:58:01][VV][api.service:043]: send_ping_response: PingResponse {}
[07:58:08][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=33034206 (now=33044206)
[07:58:12][VV][scheduler:185]: Running interval 'update' with interval=60000 last_execution=32987795 (now=33047795)
[07:58:12][VV][uart.arduino_esp8266:180]: Flushing...
[07:58:12][V][modbus:184]: Modbus write: 01.04.00.00.00.0A.70.0D (8)
[07:58:12][D][uart_debug:114]: >>> 01:04:00:00:00:0A:70:0D
[07:58:14][VV][api.service:355]: on_ping_request: PingRequest {}
[07:58:14][VV][api.service:043]: send_ping_response: PingResponse {}
[07:58:16][VV][api.service:355]: on_ping_request: PingRequest {}
[07:58:16][VV][api.service:043]: send_ping_response: PingResponse {}
[07:58:18][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=33044206 (now=33054206)
[07:58:22][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=32998125 (now=33058125)
[07:58:28][VV][scheduler:185]: Running interval '' with interval=10000 last_execution=33054206 (now=33064212)
markss
(Mark)
April 11, 2022, 11:41pm
202
I re-read this entire thread and noted several comments about swapping RX/TX so I did it physically.
I am now getting this:
09:38:08 [VV ][uart.arduino_esp8266:180]
Flushing...
09:38:08 [V] [modbus:184]
09:38:08 [V] [modbus:058]
Modbus received Byte 1 (0X1)
Modbus received Byte 4 (0X4)
Modbus received Byte 0 (0X0)
09:38:09 [V] [modbus:058]
09:38:09 [W] [modbus:096]
Modbus CRC Check failed! C022!=00
Modbus received Byte 10 (0Xa)
Modbus received Byte 112 (0X70)
Modbus received Byte 13 (0Xd)
I have tried a couple of things, including
stop_bits: 1, 2
I’m not sure if this CRC check is ‘progress’
what should i write in the location, I didn’t understand.
