How to use PZEM004T Energy Monitor with esphome
Replying to myself - any suggestions on what I can do to troubleshoot the CRC errors?
Do the sensors work? I remember that I also had couple of CRC once when I paired a pzem004t with esp. Despite the errors the thing was working fine.
Maybe you could try to re-wire or re-solder? Maybe somewhere is a bad connection which causes the errors? :thinking:
Is it possible to know what kind of 4pin connector is used for the TTL side?
(The white one soldered in PCB)
Iā€™d like to buy some pre built cables.
Thank you.
Does anyone know what resistor is soldered on the AC input side. I need to replace mine but Iā€™m not sure of the wattage. It looks like a 100ohm with 5% tolerance.
Thatā€™s a 2W resistor
thousand years later, finally, I made three pzem working great on esp8266! I did it using three diodes and one 10k resistor like the circuit indicated above! In +Vdd I connected +3.3v power source. No errors anymore! = D
Now I can focus on my next challenge, understand why bosch bme680 hates me a lot and give me always a lot of errorsā€¦
I recommend you to buy a socket kit in AliExpress, they have this interface there to sell.
Yes but there are different sockets with different distances between the pins.
So you connected the 10K resistor to 3.3V and not to 5V. There are different tutorials out there recommending both connectionsā€¦
Hello, I have a problem. I measure 3 phases.
The daily counter is not reset.
Does anyone know what could be the reason?
Iā€™m helping myself with switches now.
It is about the last part, I would like to make it fermented.
esphome:
esp8266:
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid
logger:
api:
ota:
web_server:
  port: 80
#time:
#  - platform: homeassistant
#    id: homeassistant_time
status_led:
  pin:
    number: D4
    inverted: true
modbus:
# PZEM-004T V3 Pins
uart:
  rx_pin: D2
  tx_pin: D1
  baud_rate: 9600
  - platform: wifi_signal
    update_interval: 30s
  - platform: uptime
    update_interval: 10s
#   L1
  - platform: pzemac
    address: 1
    current:
    voltage:
    power:
    energy:
      filters:
        # Wh to kWh is 0.001
        - multiply: 0.001
      unit_of_measurement: kWh
      accuracy_decimals: 3
#   L2
  - platform: pzemac
    address: 2
    current:
    voltage:
    power:
    energy:
      filters:
        - multiply: 0.001
#   L3
  - platform: pzemac
    address: 3
    current:
    voltage:
    power:
    energy:
      filters:
        - multiply: 0.001
switch:
  - platform: uart
    uart_id: PZEM
    data: [0x01, 0x42, 0x80, 0x11]
  - platform: uart
    uart_id: PZEM
    data: [0x02, 0x42, 0x80, 0xE1]
  - platform: uart
    uart_id: PZEM
    data: [0x03, 0x42, 0x81, 0x71]
# Restart
  - platform: restart
# Um 00:00 Reset
#time:
#    on_time:
#      - seconds: 0
#        minutes: 0
#        hours: 0
#        then:
#          - switch.toggle: reset1_esp
#          - switch.toggle: reset2_esp
#          - switch.toggle: reset3_esp
I donā€™t see even a total_daily_energy component in your yaml :eyes:
You use the total energy (counter) from your pzem004t which is stored in a internal eeprom and even continuous to count if your esp isnā€™t powered (your pzem004t obviously needs AC power to continue working). :rocket:
You should consider using the utility_meter in ha (available via the helper ui) to calculate daily/weekly/monthlyā€¦ energy :slot_machine:
EDIT:
Just now I see the ā€œfermentedā€ (google translate gone wrong?) part:
What you try is to reset the counter in the pzem004t, in general that should work (not sure about the uart commands) but you have commented out this section. Your esp82xx doesnā€™t have a RTC so a time source is mandatory if you want to run the reset of the counters on_time.
In the end it might be more useful and failure proof to just use the utility_meter in ha like mentioned before. :point_up:
Thanks !!!
Many people sharing their 3 phase diagram (with 3 individual PZEMs) using single AC LINE for reference voltage for all of them. This is indeed wrong and PZEMs will report totally screwed results. If you are monitoring 3 phase system, each PZEM needs to use that LINE which has CT connected. reason for that is that 50HZ sinus between L1, L2, L3 is shifted by 120 degrees, so measurement of current and voltage will be done wrong way. Internet is full of such diagrams and explanations, so I wont be describing it here.
Well, did a short image searches for 3-phase pzem004t wiring setups but after about seeking thru over 100 images I couldnā€™t even spot one that showed your described wrong wiring. Most of the images show even a single pzem with AC wiring or it shows some setups with 3 pzemā€™s but only the serial (DC) side of things.
Also I scrolled back a bit in this very long thread and also couldnā€™t spot one wiring that you explained :thinking:
Any idea were I could get such a diagram @AlfaBravoX?
As requested
# PZEM 004T V3 NODEMCU #
# Substitutions
substitutions:
  # Device Names
  device_name: "pzem_nodemcu"
  friendly_name: "PZEM 004T V3 NODEMCU"
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid:
  password: XXXXXXX
  power_save_mode: none
  manual_ip:
   static_ip: 192.168.0.105
   gateway: 192.168.0.2
   subnet: 255.255.255.0
  ap:
    ssid: "Pzem Nodemcu Fallback Hotspot"
    password: "A1i5751c9OoJ"
captive_portal:
# Enable logging
logger:
  level: DEBUG
  baud_rate: 0
# Enable Home Assistant API
api:
ota:
# Enable Web server.
web_server:
  port: 80
text_sensor:
  - platform: version
    name: "ESPHome Version ${friendly_name}"
# Example configuration entry
  - platform: wifi_info
    ip_address:
      name: ESP IP Address ${friendly_name}
    ssid:
      name: ESP Connected ${friendly_name}
    bssid:
time:
# LCD Display
i2c:
  sda: D6
  scl: D5
  scan: True
display:
  - platform: lcd_pcf8574
    dimensions: 20x4
    address: 0x27
    lambda: |-
      it.printf(0, 0, "DAILY ENERGY:%.1f kWh", id(${device_name}_daily_energy_total).state);
      it.printf(0, 1, "POW:%.1f W", id(${device_name}_power).state);
      it.printf(10, 1, "AMPS:%.1f A", id(${device_name}_current).state);
      it.printf(0, 2, "%.1fV", id(${device_name}_voltage).state);
      it.printf(8, 2, "%.1fPF", id(${device_name}_power_factor).state);
      it.printf(14, 2, "%.1fHz", id(${device_name}_frequency).state);
      it.strftime(0, 3,"%H:%M %d.%m", id(homeassistant_time).now());
      it.printf(12, 3, "%.1f db", id(${device_name}_wifi_signal).state);
uart:
  rx_pin: D1
  tx_pin: D2
  baud_rate: 9600
  stop_bits: 1
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    frequency:
      name: "${friendly_name} Frequency"
    power_factor:
      name: "${friendly_name} Power Factor"
      unit_of_measurement: pf
    update_interval: 2s
  - platform: total_daily_energy
    name: "${friendly_name} Total Daily Energy"
    power_id: ${device_name}_power
    filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
    icon: mdi:counter
  - platform: integration
    name: "${friendly_name} Energy Meter"
    sensor: ${device_name}_power
    time_unit: h
    filters:
      - multiply: 0.001
    icon: mdi:counter
  # Sensors with general information.
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
    name: ${friendly_name} WiFi Signal
    update_interval: 60s
binary_sensor:
  - platform: status
status_led:
  pin:
     number: D4
     inverted: false
this is correct connection http://puaks.blogspot.com/2021/07/cara-aman-merakit-kwh-3-phase-dengan.html
Color of wires are definitely wrong for European regulations but for explanation it is fine
consider in (EU):
Blue (in real cable must be black, grey or brown color) L1
Yellow (in real cable must be black, grey or brown color) L2
Red (in real cable must be black, greym or brown color) L3
Black (in real cable must be blue color) N
and explanation why in 3 phase monitoring we need to use reference from 3 different Lines is here: https://electronics.stackexchange.com/questions/12851/why-is-three-phase-offset-by-120-degrees#:~:text=When%20thereā€™s%20120%C2%B0%20between,the%20return%20line%20(neutral).
yes, correct, thanks for pointing this out. updated the post.
Would a diode with the following specifications work for this application?
or this one?
The spec you should be looking at is voltage drop. Around 0.3V is fine. Otherwise just give your diode a try.
