How to use remote python debugging
I have a HA green and cloud. I am trying to debug a custom integration. I am following this guide:
Remote Python Debugger - Home Assistant. My issue is that I am not able to connect to my HA instance using ssh from visual studio code. I am using Mac M1 and able to connect to HA via ssh from mac terminal. However I get the following error in vscode.
[12:15:08.839] stderr> ps: unrecognized option: p
[12:15:08.853] > Exec server process not found
Here is the full log.
[12:15:08.713] > ready: b46f9139005b
[12:15:08.724] > Linux 6.6.20-haos #1 SMP PREEMPT Wed Mar 13 13:09:44 UTC 2024
[12:15:08.724] Platform: linux
[12:15:08.732] > /bin/zsh
[12:15:08.733] Shell: zsh
[12:15:08.733] Creating bash subshell inside "zsh"
[12:15:08.755] > bash version:  5.2.21(1)-release
[12:15:08.778] > b46f9139005b: running
[12:15:08.808] > Found existing installation at /root/.vscode-server...
> Starting VS Code CLI... "/root/.vscode-server/code-903b1e9d8990623e3d7da1df3d33db3e42d80eda" command-shell --cli-data-dir "/root/.vscode-server/cli" --on-port --parent-process-id 386 &> "/root/.vscode-server/.cli.903b1e9d8990623e3d7da1df3d33db3e42d80eda.log" < /dev/null
[12:15:08.810] > printenv:
[12:15:08.816] >     SHELL=/bin/zsh
>     SUDO_GID=1000
>     CHARSET=UTF-8
>     SUDO_COMMAND=/bin/zsh
>     SUDO_USER=hassio
>     PWD=/root
>     LOGNAME=root
>     TZ=America/Chicago
>     HOME=/root
>     LANG=C.UTF-8
>     VSCODE_AGENT_FOLDER=/root/.vscode-server
>     TERM=unknown
>     USER=root
>     SUPERVISOR_TOKEN=46f4effa61b7fee58e13eddd59b0ca2ad6f9e9b081625127277478aabead648d5860c4af10e21ca71f08b734db18742bc10c9c3ed82e12ea
>     SHLVL=2
>     PAGER=less
>     LC_COLLATE=C
>     PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
>     SUDO_UID=1000
>     MAIL=/var/mail/root
>     OLDPWD=/root
>     _=/bin/printenv
[12:15:08.820] > Removing old logfile at /root/.vscode-server/.cli.903b1e9d8990623e3d7da1df3d33db3e42d80eda.log
[12:15:08.823] > Spawned remote CLI: 406
**[12:15:08.839] stderr> ps: unrecognized option: p**
**[12:15:08.853] > Exec server process not found**
[12:15:08.854] stderr> BusyBox v1.36.1 (2023-11-07 18:53:09 UTC) multi-call binary.
[12:15:08.854] stderr> Usage: ps [-o COL1,COL2=HEADER] [-T]
[12:15:08.854] stderr> Show list of processes
[12:15:08.854] stderr> 	-o COL1,COL2=HEADER	Select columns for display
[12:15:08.854] stderr> 	-T			Show threads
[12:15:08.864] > b46f9139005b: start
> SSH_AUTH_SOCK====
> DISPLAY====
> listeningOn====
> osReleaseId==alpine==
> arch==aarch64==
> vscodeArch==arm64==
> bitness==64==
> tmpDir==/tmp==
> platform==linux==
[12:15:08.872] > unpackResult====
> didLocalDownload==0==
> downloadTime====
> installTime====
> serverStartTime==0==
> execServerToken==1a1a1111-11a1-1aaa-11aa-11aaa1a1a1a1==
> b46f9139005b: end
[12:15:08.872] Received install output:
SSH_AUTH_SOCK====
DISPLAY====
listeningOn====
arch==aarch64==
vscodeArch==arm64==
bitness==64==
tmpDir==/tmp==
platform==linux==unpackResult====
downloadTime====
installTime====
[12:15:08.873] Failed to parse remote port from server output
[12:15:08.873] Terminating local server
[12:15:08.875] Resolver error: Error:
	at g.Create (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:460245)
	at t.handleInstallOutput (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:457567)
	at e (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:518696)
	at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
	at async /Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:540605
	at async t.withShowDetailsEvent (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:544264)
	at async /Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:515401
	at async T (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:513452)
	at async t.resolveWithLocalServer (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:514941)
	at async k (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:537822)
	at async t.resolve (/Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:541635)
	at async /Users/vgoya2/.vscode/extensions/ms-vscode-remote.remote-ssh-0.108.0/out/extension.js:2:807794
[12:15:08.879] ------
Here is the error in my ā€œAdvanced SSH and web terminalā€ add-on (which works fine)
Accepted password for hassio from 192.168.4.20 port 65386 ssh2
User child is on pid 435
Starting session: shell for hassio from 192.168.4.20 port 65386 id 0
Received disconnect from 192.168.4.20 port 65386:11: disconnected by user
Disconnected from user hassio 192.168.4.20 port 65386
Please help me understand how to fix this.
Thank you.
I’ve had the same issue with VS Code Server.
Looks like it’s trying to use ps -p which isn’t available with the BusyBox version of ps.
I just installed a different version with apk --no-cache add procps and it now works.
Edit: added procps to the Advanced SSH & Web Terminal packages config instead so it automatically installs on startup.
Edit 2: this is no longer an issue - procps is included by default:
Thanks so much! This worked perfectly.
Adding the package manually works for me, thanks! Nevertheless, I can’t add it through the package config like this:
packages:
  - procps
Any ideas?
I’m using the Terminal & SSH add-on, and for me I use apks instead of packages. I was running into the same issue as OP and adding procps this way worked for me.
apks:
  - gcompat
  - libstdc++
  - curl
  - procps
