I have a rest sensor (see RESTful - Home Assistant). Note that this is not the same as RESTful Sensor - Home Assistant!
The JSON data is returned with a unit (eg. 2936 MW
), which I want to remove so I can use it in a graph:
According to the docs (RESTful - Home Assistant) I can use any RESTfull config option in a sensor
, how ever I can’t figure out how to use value_template
(RESTful Sensor - Home Assistant).
As a workaround I added separate template sensors:
rest:
# Swissgrid
# Use the templated sensors swissgrid_import_none, resp. their friendly name swissgrid_import_XX
- resource: https://www.swissgrid.ch/bin/services/apicache?path=/content/swissgrid/de/home/operation/grid-data/current-data/jcr:content/parsys/livedatawidget_copy
- name: swissgrid_raw_meta0
json_attributes_path: $.data.table[0]
value_template: "OK"
json_attributes:
- label
template:
- name: swissgrid_import
state: "{{ state_attr('sensor.swissgrid_raw_meta0', 'label').split(' ')[2] | int }}"
unit_of_measurement: "MW"
How ever there should be a way to do this directly in the rest
sensor, right?
