Hi there,
What I would like to do is create a conditional card (that only shows on the dashboard in certain conditions). That works. But what I want it to contain is a warning tekst and also using the content of a specific sensor. In this case I want to display a warning when visibility is below 500m.
For instance:
Warning Visibility belof 500m. Current visibility 450m
Where "450m* should be the actual visibility derived from sensor.knmi_zicht
What I have so fare is:
I’ve created a helper “Mist” of the type input.text
I’ve created an automation with the follwing code:
alias: Mist onder 500m
description: Test of de mist onder 500m zicht is en toont een waarschuwing via Helper Mist
triggers:
- trigger: numeric_state
entity_id:
- sensor.knmi_zicht
below: 500
conditions: []
actions:
- action: input_text.set_value
metadata: {}
value: "*WARNING*: Visibility below 500m"
entity_id: input_text.mist
mode: single
This works and it shows the text behind ‘value’ in the card.
Now I would like to add the current visibility (eg. the content of sensor.knmi_zicht) to the text so that it reads
WARNING: Visibility below 500m. Current visibility xxxm
Where xxx obviously is the content of the sensor.knmi_zicht
I’ve been searching for this but haven’t found a solution. Sorry for those that feel this is a noob question…correct…I am
Ow and perhaps, if you can. Please tell me how to format text within standard cards so that I can make WARNING bold or even a different font type. Thanks
