Hey there. First post here. Have been using HA for a couple of months and loving its robust flexibility.
Was wondering if anyone has had any luck using this IOS lock screen widget. Thought it might be helpful in displaying state of garage door on lock screen. Apologies if this is covered somewhere else. Have been holding off for a while to ask to thouroughly search but no luck.
Hey. With the Lock Screen active long press somewhere in the middle of the screen this should bring up a customize button at bottom of screen. Click that, select the Lock Screen option on left. Tap the widget area, then tap the widget you want to edit. This should bring up the screen you’re wanting.
For help with actually designing the template you will need to “write” some code. In Home Assistant, go to Developer Tools, then Template. Modify the sample code, and if the preview there works, copy that into the upper and lower text template of the ios widget
No, I don’t know why it takes so long to update the lockscreen widget. You would think it would be instantaneous, but nope. Anyone figure this out yet?
But you will create various widgets for the BG values.
Also, at some point recently, Dexcom started sending plenty of digits. So I made helper sensors to get rounded values.
Also, on the Lock Screen, the widgets are limited to 4 x Circles, or 2 x Circles + 1 “double” circle? Oval?
This led me to create helper sensors for each digit of BG value:
ie: tens, ones, tenths, and another for either the decimal and an icon for trending.
Much like HA widgets, Widgy Widgets is also limited in background updates forced upon everything from Apple. However, the main difference with Widgy is that just a single tap on the widget will refresh the value.
I know this thread is kind of old, and I don’t know how I came upon it.
But if you’re interested in more info on how to achieve this, send me a message
thank you Lewis
i tried Widgy, this is very cool! a masterpiece of app/software. Update on tap also works pretty well but i ended up using Shuggah. it connects directly to the dexcom and has realtime notification/view on lockscreen. Also connected to nightscout so no need for dexcom cloud anymore.
