How to use trigger source in an action
I have automation with several triggers, how can I know the source in order to create a conditional template to define a different comfort temperature according to a flag which will indicate Comfort +.
My wish is to limit the number of automations … Otherwise I could do that with multiple copy / paste …
- alias: 'CONFORT Séjour Semaine'
    value_template: '{{ states.sensor.time.state == states.input_datetime.sejour_start_semaine_matin.state[0:5] }}'
    value_template: '{{ states.sensor.time.state == states.input_datetime.sejour_start_semaine_midi.state[0:5] }}'
    value_template: '{{ states.sensor.time.state == states.input_datetime.sejour_start_semaine_soir.state[0:5] }}'
# Conditions are used for other things... time:, workday: etc...
  - service: climate.set_temperature
    entity_id: climate.thermostat_sejour
    data_template:
      temperature: '{% if is_state("input_boolean.boost_sejour_semaine_matin", "on") %}
                      {{ states.input_number.consigne_confort_plus.state }}
                   {%-elif is_state("input_boolean.boost_sejour_semaine_matin", "off") %}
                      {{ states.input_number.consigne_confort.state }}
                   {% endif %}'
Flag is input_boolean, Start time is input_datetime
Temperatures are input_number
Trigger is an object available in automation templates.
Yes, I have Google and I read this, but I find an exemple…
There is an example at the bottom of the page @brahmafear linked to.
trigger.entity_id
Also to prevent errors do not use these forms:
Use these instead:
states('sensor.time')
states('input_datetime.sejour_start_semaine_matin')[0:5]
Thank you @tom_l for your constructive remarks.
However “{{trigger.entity_id}}” returns me “sensor.time” but not which of the three triggers …
You could put the same templates from your trigger section in an if-elseif block in action section to determine which evaluated to true.
My result (in french)
