How to use tuya device on Home assistant?
Hi there, i m a newbie here,i have got some device(light,smart plug) which could perfectly run on Tuya app.And i could make some easy scenario with the iot page from themhttps://developer.tuya.com/en/The problem is:the devices could not work on Home assistant…Could anyone help? Thanks a million!
use the tuya or tuyalocal integration, you can find how to setup on youtube.
if you want cloudbased use Tuya, if not look at localtuya.
Thanks for your reply!Maybe it is too entry level-how is the control performance of Tuya Integration? :eyes:you mean i could not use cloud control while using tuyalocal integration,am i right?
as far as i know you can, but if there is an update form the cloud solution it’s possible that breaks localtuya connection.
I prefer to take as many items out of the cloud as possible, so if a lose my internet connection i can still manage them.
If u use localtuya then my advise will be to disconnect/not use your offical app because it can push an update to your devices.
