How to use Utility Meter Tariffs to conditionally measure things
The Utility Meter integration is used to measure accumulating values like energy, gas, water, heating and more.
You can apply a cycle to make it reset whenever you want. So, for example, you can make a daily energy meter from a sensor that always increases.
You can also use the tariffs option to create multiple conditional sensors from the one utility meter.
Every tariff you define gets its own sensor and you can automate when that sensor starts accumulating.
This is a powerful tool allowing you to track things like peak and off-peak energy use, or water used when a particular device is on. Or which member of your house uses the most energy on a particular day for washing.
For example, lets say you have a binary sensor that tells you if your energy is being charged at peak or offpeak rates, binary_sensor.peak_rate and you would like to track both off-peak and peak daily energy use separately, but you only have the one energy import sensor that never resets, sensor.energy_import.
1) Define a daily cycle utility meter with two tariffs:
configuration.yaml, or via the Helpers UI
utility_meter:
  energy_from_grid_daily:
    source: sensor.energy_import
    cycle: daily
    tariffs:
      - peak
      - offpeak
This will create two sensors, sensor.energy_from_grid_daily_peak and sensor.energy_from_grid_daily_offpeak.
It will also create a select entity to allow you to choose between the two sensors, select.energy_from_grid_daily. This select entity will have the two options, peak and offpeak. Whichever option is chosen starts the associated sensor accumulating.
2) Write an automation to choose which sensor gets to accumulate energy based on your binary sensor state:
automations.yaml, or using the UI automation editor
- id: 841ae395-4646-4c95-8991-14cdd7e9c834
  alias: 'Set Peak or Off-peak Tarrif'
    - platform: state
      entity_id: binary_sensor.peak_rate
      not_to:
        - unknown
        - unavailable
    - if:
        - condition: state
          state: 'on'
      then:
        - service: select.select_option
            entity_id:
              - select.energy_from_grid_daily
              option: 'peak'
      else:
            entity_id:
              option: 'offpeak'
A shorter way to do this with templates:
        entity_id:
          option: >
            {{ 'peak' if is_state('binary_sensor.peak_rate','on') else 'offpeak }}
The Home Assistant Cookbook - Index.
Energy consumption for a specific time window
Utility_meter based on energy Counter if switch is on
Trying to track energy usage per day of the week and keep an average
Utility Meter showing as selector
Measuring charging the electric car only when charging at home
How to measure consumption of device only when using power grid
Attributing solar energy to individual devices to help measure how changed behaviours can improve carbon footprint
Energy used between two timestamps
Why are people asking the same questions over and over again? (Or the Regulars' Chatroom) 🤷
Utility meter for different tariffs... during different times of year?
Home Assistant Cookbook - Discussion Thread
Count solar / grid (day and night) energy cunsumption of a device (EV charger)
How to configure for “3 free” hours of electricity
Energy integrator not integrating properly
Is it possible to see how much Solar Power my Shelly / Tasmota Devices have used
Differentiating the imported energy based on the hour of the day
How to get separately input and output energy from a Shelly device?
29 / 5.000 consumption recording sensors
Peak / Off-Peak energy consumption based on existing smart plug data
Automation changing entity value based on weekday and time
Sensor watts sum over set time range?
Power usage during certain periods of the day
Help setting up a dual energy tarif
Separate increasing and decreasing sensor
A post was split to a new topic: Determine if battery is being used
