Hi all, new to HA and ESPHome and getting started with automation but finding it a challenge for sure.
End goal here is to use a photocell to continually adjust the brightness setting of a light entity - in this case the backlight of an LCD display.
LDR is connected to a D1 mini and returns between 0 and 1 V or 0 and 100 is using a calibrate_linear filter. Not sure if the unit_of_measurement
is an issue here as it defaults to V.
#esp-ldr.yaml
- platform: adc
pin: A0
name: "Test Brightness"
filters:
- calibrate_linear:
- 0.0 -> 0.0
- 1.0 -> 100.0
update_interval: 2s
The LCD backlight is set via pmw pin on a separate D1 mini connected to the backlight pin on the pcf8574
#esp-lcd.yaml
output:
- platform: esp8266_pwm
pin: GPIO12
light:
- platform: monochromatic
output: backlight
name: "LCD Display Backlight"
restore_mode: ALWAYS_ON
I can control the backlight state and brightness via the GUI no probs. I cobbled the below together from other posts and here and have entered as a script.
#automation script
light_adjust_ldr:
alias: LCD Brightness
sequence:
- service: light.turn_on
device_id: f533e67745a4556d7e5f32ed602abd53
entity_id: light.lcd_display_backlight
domain: light
data_template:
brightness_pct: "{{ states('sensor.test_brightness' }}"
mode: single
but it doesn’t work and throws an error in the trace: extra keys not allowed @ data[‘domain’]
was oringally
brightness_pct: "{{ states('sensor.test_brightness' |float}}"
but this does return a value when tested in templates but does without the | float
. I’m also unsure what the trigger would be for this automation how to run it on a regular schedule.
Grateful for any tips.
