How to use winscp to send file tom HA
Hello
When I use this app for sending files to HA i get access denied.
I am usining FTP and SFTP same problem.
/Tommy
Install the SSH and web terminal community add-on and use SSH instead.
i am not very good at terminal use command so I like to use winscp to transfer files
Can you give me example for command to use
/Tommy
What Tom says is that you have to install the “SSH and web terminal community add-on” inside HA.
Then you can use WinSCP, but using the SSH/SCP protocol rather than FTP/SFTP.
Tanks for your ansver. I tryed that and no access
/Tommy
Please be more specific in what you have done and what does and doesn’t work.
I have installed terminal and SSH, started terminal, startet WinSCP and tryed to log in using SCP protocol. Access denied.
/Tommy
Maybe watch that video that describes exactly what you are trying to achieve.
Tanks for the respond, I have done this and when I check log in SSH it says
legacy-services successfully started
[09:58:30] WARNING: SSH port is disabled. Prevent start of SSH server.
Now it works added port 22 and it works. Thans for all help
/Tommy
