How To Using Action Selectors in Blueprints
This is a solution for passing and executing actions dynamically in Home Assistant blueprints and scripts. The solution emerged through discussions with ChatGPT and was inspired by user nwithan8 and others in this thread.
Problem
The task was to execute actions defined during the configuration of a motion-activated blueprint. Passing an action as a runtime variable proved challenging considering that the action selector returns a list of actions.
Solution
The approach involves executing the action set during configuration by employing a choose condition in the action sequence since the choose condition will take a list of actions.
Here is a snippet of the action selector:
action_to_run:
  name: Action to run.
  description: Action to run when triggered.
  selector:
    action: {}
choose with action_to_run as default:
- alias: "Run the action"
  choose: []
  default: !input action_to_run
Here’s the solution in an example blueprint (which is a modification of the default motion_light.yaml):
blueprint:
  description: Run an action when motion is detected, run another action after waiting for a period of no motion.
  domain: automation
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    on_action:
      description: Action to run when motion is detected.
      selector:
        action: {}
    off_action:
      description: Action to run when motion is no longer detected.
      selector:
        action: {}
    no_motion_wait:
      description: Time to wait until off_action is called.
      default: 2
      selector:
        number:
          min: 0
          max: 60
          unit_of_measurement: minutes
variables:
  delay_var: !input no_motion_wait
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
  - alias: "Run the on action"
    choose: []
    default: !input on_action
  - wait_for_trigger:
      platform: state
      to: "off"
  - delay: "{{ delay_var | multiply(60) }}"
  - alias: "Run the off action"
    choose: []
    default: !input off_action
Here, choose has an empty list of conditions and default executes the action passed as on_action and off_action.
This method adds flexibility, as it allows actions performed to be defined at the time of configuring the blueprint or script.
Thanks for this! This works well for Blueprints, but I was trying to use the Action Selector in a “normal” (non-Blueprint) script. This approach didn’t work because !input is only available for Blueprints. I see this thread is referenced in a few places, so I wanted to share my solution in case anybody else is in the same boat as me. Suggestions and improvements are welcome :).
I ended up with the following low-tech solve (where action is the field that uses the Action Selector). It’s a bit hacky because I needed to handle the permutations of the target and/or data being undefined.
- repeat:
    for_each: "{{ action }}"
    sequence:
      - choose:
        - conditions: "{{ repeat.item.target is defined and repeat.item.data is defined }}"
          sequence:
            - service: "{{ repeat.item.service }}"
              target: "{{ repeat.item.target }}"
              data: "{{ repeat.item.data }}"
        - conditions: "{{ repeat.item.target is defined }}"
          sequence:
        - conditions: "{{ repeat.item.data is defined }}"
          sequence:
        default:
Since this is a pain to repeat in all of my scripts, I defined a helper script for doing this:
  alias: _ Execute Action
  mode: parallel
  fields:
      required: true
      selector:
  sequence:
    # (loop from above goes here - omitted for brevity)
And then I can use the helper script like so:
- service: script.action
    action: "{{ foo }}"
Cheers!
@JacobSnyder
This works great, few limitation when we are actually not using service, like delay or other, but it the solution works great.
Probably adding another conditions for each case will work as well.
Thanks!
This works really well!
Heads up, for 2024.8, “service” have been renamed to “action”.
I simply had to replace repeat.item.service with repeat.item.action. I did NOT have to replace - service: with -action:, as (for now), Home Assistant accepts both as YAML keys
I ran into the same issue and the solution in the other thread worked for me, so I created a really simple blueprint for it. It is a script that will execute one or more actions after a specified delay.
To install this, push this magic button:
Import Blueprint 'Do After Delay'
Or do it by hand - it goes in: blueprints/script/homeassistant/do_after_delay.yaml
blueprint:
  name: Do After Delay
  description: Perform one or more actions after a specified delay, in minutes.
  domain: script
  homeassistant:
    min_version: '2025.7.0'
  author: 'qJake - https://community.home-assistant.io/u/qjake'
mode: parallel
max: 50
fields:
  delay_mins:
    description: How long to delay the action(s) for. Max is 1440 minutes.
    required: true
    default: 5
    selector:
      number:
        min: 0
        max: 1440
        step: 5
    description: The action(s) to perform.
    required: true
    selector:
sequence:
  - delay:
      hours: 0
      minutes: "{{ delay_mins }}"
      seconds: 0
      milliseconds: 0
  - repeat:
      sequence:
        - choose:
            - conditions:
                - condition: template
                  value_template: >-
                    defined }}
              sequence:
                - target: "{{ repeat.item.target }}"
                  action: "{{ repeat.item.action }}"
            - conditions:
                  value_template: "{{ repeat.item.target is defined }}"
              sequence:
            - conditions:
                  value_template: "{{ repeat.item.data is defined }}"
              sequence:
                - data: "{{ repeat.item.data }}"
          default:
            - action: "{{ repeat.item.action }}"
Hey all, I was working on getting the Action Selector to work in a Blueprint with other actions. This is what I came up with as a clean implementation, using Sequence. It all seems to be working fine. Any down sides to this?
Input Snippet:
input:
  alert_actions:
    default: []
    selector:
Actions Snippet:
actions:
  - action: counter.increment
    metadata: {}
    data: {}
      entity_id: !input alert_level_counter
  - sequence: !input alert_actions
UPDATE: I think I’ve answered my own question from the docs:
Grouping actions in a sequence can be useful when you want to be able to collapse related groups in the user interface for organizational purposes.
