How to utilize multiple instances of df_player_mini
I have a system with 5 separate ESPHomes connected with a DF player mini to play audio. Currently I have it working by having a separate ESPHome yaml file for each one, and I change the name of the device as well as all of the buttons I have defined, so that each of the instances have a unique entity name. The issue with this is that if I want to make a global change to the ESPHome coding, I have to recompile 5 times and upload them to each of the ESPHomes. Is there some way I can utilize the same binary file for each, and have some other way to uniquely identify each instance in Home Assistant?
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
number:
    max_value: 100
    min_value: 1
    step: 1
    mode: box
    optimistic: true
    on_value:
      then:
         dfplayer.play: !lambda 'return x;'
    max_value: 30
    min_value: 1
    step: 1
    mode: slider
    optimistic: true
    on_value:
      then:
         dfplayer.set_volume: !lambda 'return x;'
button:
    on_press:
      - dfplayer.pause
    on_press:
      - dfplayer.start
    on_press:
      - dfplayer.volume_up
    on_press:
      - dfplayer.volume_down
# Enable Home Assistant API
api:
  services:
  - service: dfplayer_next
    then:
      - dfplayer.play_next:
  - service: dfplayer_previous
    then:
      - dfplayer.play_previous:
  - service: dfplayer_play
    variables:
      file: int
    then:
      - dfplayer.play: !lambda 'return id(MP3_1_volume).state;'
      #- dfplayer.play: !lambda 'return file;'
  - service: dfplayer_play_loop
    variables:
      file: int
      loop_: bool
    then:
      - dfplayer.play:
          file: !lambda 'return file;'
          loop: !lambda 'return loop_;'
  - service: dfplayer_play_folder
    variables:
      folder: int
      file: int
    then:
      - dfplayer.play_folder:
          folder: !lambda 'return folder;'
  - service: dfplayer_set_volume
    variables:
      volume: int
    then:
      - dfplayer.set_volume: !lambda 'return volume;'
  - service: dfplayer_set_eq
    variables:
      preset: int
    then:
      - dfplayer.set_eq: !lambda 'return static_cast<dfplayer::EqPreset>(preset);'
  - service: dfplayer_sleep
    then:
      - dfplayer.sleep
  - service: dfplayer_reset
    then:
      - dfplayer.reset
  - service: dfplayer_start
    then:
      - dfplayer.start
  - service: dfplayer_pause
    then:
      - dfplayer.pause
  - service: dfplayer_stop
    then:
      - dfplayer.stop
  - service: dfplayer_volume_up
    then:
  - service: dfplayer_volume_down
    then:
uart:
  tx_pin: GPIO2
  rx_pin: GPIO4
  baud_rate: 9600
# Declare DFPlayer mini module
dfplayer:
  on_finished_playback:
    then:
      logger.log: 'Somebody press play!'
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-129835"
    password: "H05KGbeGEsm8"
captive_portal:
I don’t think so. If there was, working it out would take longer than five presses of ‘update’
