How to: virtual esphome device and development using Windows (work in progress!)
Please note: work in progress!
Hey everyone,
I recently set up the development environment that allows me to try out esphome display layouts without having to flash code onto an actual physical device. This makes it faster to try things out, and you don’t even need to have the device around yet for which you want to design something.
Please note: this post is mostly written as a draft for a potential extension for SDL2 Display on host platform — ESPHome, and highly based on my own single experience, so any feedback that makes this more correct and easier to follow: bring it on, highly appreciated :slight_smile:
Who is this suitable for: anyone who wants to code esphome display stuff without having to use an actual device, who works with a Windows10 laptop/pc, and who is comfortable with doing commandline stuff.
Who is this not suitable for: Mac/Linux users (from what I understood the stuff in SDL2 Display on host platform — ESPHome already got you covered), people who depend on the esphome environment within HA for development
What you will have once setting everything up: you’ll be able to write, compile and “flash” code on your Windows system and have it running as a virtual esphome device, including the connection to your live HA instance (as long as your laptop runs in the same network).
A lot of the basic steps were originally lined out in Discord, so thanks to the people involved for laying the groundwork :slight_smile:
Steps needed:
  1. Download and install Visual Studio Code: Download Visual Studio Code - Mac, Linux, Windows
  2. If not automatically available: find and install the WSL extension in VS code
  3. Install the Windows Subsystem for Linux (WSL): open the Windows command line as an administrator (via right-click on the command line icon) and run
wsl --install
(details via Install WSL | Microsoft Learn if needed)
  1. Install SDL2 within the linux environment: run
sudo apt install libsdl2-dev libsodium-dev build-essential git
and wait until everything is done.
  1. Update python if needed, install the venv module for virtual environments, and create a virtual environment.
sudo apt-get update
sudo apt-get install libpython3-dev
sudo apt-get install python3-venv
python3 -m venv chooseanamehere
(“chooseanamehere” is a placeholder for whatever name you want to give your virtual environment and its folder, replace it with what you like, e.g. “virtualesphome”. Going on from here, everywhere you read “chooseanamehere” in this document replace it with whatever you picked in the end)
  1. Start the virtual environment you just created
source chooseanamehere/bin/activate
The terminal commandline should now have the name of the virtual environment in brackets at the front.
  1. Navigate into the folder of your virtual environment and Install esphome
cd chooseanamehere
pip3 install wheel
pip3 install esphome
(Details via Installing ESPHome Manually — ESPHome)
  1. Open your venv folder for the first time in Visual Studio Code by running
code .
inside the WSL command line, this will complete the initial connection between WSL and Visual Studio Code (see Developing in the Windows Subsystem for Linux with Visual Studio Code for details)
  1. Create a minimal yaml file inside the virtual environment folder and try out your first compilation/run via “esphome compile example.yaml” or “esphome run example.yaml” in the Visual Studio Code WSL terminal.
Minimal example yaml:
esphome:
host:
display:
  - platform: sdl
    #show_test_card: true
    dimensions:
      width: 480
      height: 320
    auto_clear_enabled: false
touchscreen:
  platform: sdl
lvgl:
  #log_level: INFO
  color_depth: 16
  bg_color: 0x000000
  pages:
    - id: main_page
      widgets:
        - label:
            text_font: montserrat_36
            text: "hello world"
            align: center
            text_color: 0xFFFFFF
After shutting down your laptop or restarting Visual Studio Code you might need to reactivate your virtual environment via
in the WSL terminal to continue working with the setup.
Connecting the virtual esphome device to your HA instance
The esphome node you run will not be autodetected by HA as usual, this needs additional steps:
  1. Windows needs to forward the esphome network connection to the virtual device, you can set that up using
netsh interface portproxy add v4tov4 listenport=6053 listenaddress=0.0.0.0 connectport=6053 connectaddress=172.123.123.123
in the windows command line. Replace the last ip address with the ip address your WSL environment has (find out by running “ifconfig” in your WSL environment)
  1. Run a working yaml file and start the esphome node via Visual Studio Code and keep it running (aka: don’t close the small esphome display window that pops up after you execute “esphome run …”)
  2. Add the esphome node manually in HA via Settings => Devices => esphome => “add device” and use the ip address of your laptop (not the one of the WSL environment)
This now allows you to e.g. use real sensor values from HA inside your virtual esphome node.
That’s it for now, more work to do here though:
ToAdd: more screenshots, notes about touchscreen support, …
Oh WOW!!, well done in turning my ramblings on the ESPHome Discord into something useful!!
I must say that if anyone is putting together an ESPHome display be it with LVGL or not, this tool is can be a great time saver. Compiling the board over and over again and having to wait for it can be painful.
Thanks for sharing. Really appreciated.
I tried it with succes, but stumbled upon some minor missing parts. No big deal, but I can imagine fresh starters could save some time in figuring out with these extra steps:
May I suggest you to add the step sudo apt-get update after the quoted step 3. (I don’t know why the quote makes 1 of it) above?
Otherwise the package: “libsdl2-dev” cannot be found on clean installs.
Right now this is covered in step 5 but is already needed at step 4.
Another suggestion on this quoted text:
ifconfig is by default not available in WSL and can be installed by running sudo apt install net-tools
Thanks, very helpful (most I had figured out myself but the code . thing was new :slight_smile: ).
The one part I am struggling with is connecting to homeassistant from WSL2
Adding
api:
to the code works as far as I can tell (vscode even notes that port 6053 has been opened) and the log shows (I can even connect to localhost:6053 from windows and see it in the debug output):
[13:40:32][C][logger:177]: Logger:
[13:40:32][C][logger:178]:   Max Level: DEBUG
[13:40:32][C][logger:179]:   Initial Level: DEBUG
[13:40:32][C][sdl:034]: SDL
[13:40:32][C][sdl:034]:   Rotations: 0 °
[13:40:32][C][sdl:034]:   Dimensions: 800px x 480px
[13:40:32][C][lvgl:086]: LVGL:
[13:40:32][C][lvgl:087]:   Display width/height: 800 x 480
[13:40:32][C][lvgl:088]:   Rotation: 0
[13:40:32][C][lvgl:089]:   Draw rounding: 2
[13:40:32][C][mdns:116]: mDNS:
[13:40:32][C][mdns:117]:   Hostname: sdl
[13:40:32][C][api:140]: API Server:
[13:40:32][C][api:141]:   Address: :6053
[13:40:32][C][api:145]:   Using noise encryption: NO
But even after adding portforwarding in windows
PS C:\Users\gabri> netsh interface portproxy show v4tov4
Listen on ipv4:             Connect to ipv4:
Address         Port        Address         Port
0.0.0.0         6053        172.30.151.99   6053
and poking homeassistant to manually add the device (on windowsip:6053) nothing happens. Did you reconfigure the firewall somehow? I already added a Incoming allow for port 6053, no luck with that, either.
Edit: BTW to simplify the portforward setup, use powershell and wsl hostname -I to provide the WSL IP:
sudo netsh interface portproxy add v4tov4 listenport=6053 listenaddress=0.0.0.0 connectport=6053 connectaddress=(wsl hostname -I)
OK, utterly bizarre but the following works.
192.168.1.20    6053        127.0.0.1       6053
Seems like esphome somehow binds to the wrong IP ?!?!?
I have more success also adding a connection from 0.0.0.0 to 127.0.0.1 with the following command:
netsh interface portproxy add v4tov4 listenport=6053 listenaddress=0.0.0.0 connectport=6053 connectaddress=127.0.0.1
The connection however is no longer possible, when I exit and reopen the SDL window. I have to remove the connection and add it again. Has anyone found a reliable setup?
Hello. Very usefull topic. But after update Win10-Win11, I’ve got problem again.
First I’ve tried:
Create or edit %UserProfile%\.wslconfig on Windows:
[wsl2]
localhostForwarding=true
But got nothing.
Solved problem with this two steps in Powershell (from admin):
netsh interface portproxy add v4tov4 listenport=6053 listenaddress=0.0.0.0 connectport=6053 connectaddress=172.28.78.119
New-NetFirewallRule -DisplayName "WSL Port 6053" -Direction Inbound -LocalPort 6053 -Protocol TCP -Action Allow
Replace 172.28.78.119 with wsl internal ip.
Without second step firewall blocks connection to host_ip:6053. Only allows localhost:6053.
