What kind of card would you recommend for that? Thanks!
I use the Australian ARPANZA service via a rest sensor and an apexchart for display:
type: custom:apexcharts-card
apex_config:
chart:
height: 100%
dataLabels:
background:
enabled: false
style:
colors:
- var(--primary-text-color)
graph_span: 24h
header:
show: true
show_states: true
title: UV Index
experimental:
color_threshold: true
yaxis:
- id: left
decimals: 1
apex_config:
forceNiceScale: true
series:
- entity: sensor.uv_index
stroke_width: 2
type: line
color: rgb(192,192,192)
yaxis_id: left
float_precision: 0
statistics:
type: max
period: 5minute
align: middle
show:
datalabels: false
extremas: false
name_in_header: false
color_threshold:
- color: '#b200ff'
value: 10.5
- color: '#e45e65'
value: 7.5
- color: '#ff8000'
value: 5.5
- color: '#e0b400'
value: 2.5
- color: '#0da035'
value: 0
header_actions:
tap_action:
action: more-info
If you want a bar chart that can be done too.
apex_config:
chart:
height: 100%
dataLabels:
background:
enabled: false
style:
colors:
graph_span: 24h
header:
show: true
show_states: true
title: UV Index
experimental:
yaxis:
- id: left
decimals: 1
apex_config:
series:
type: column
float_precision: 1
group_by:
func: last
duration: 1h
show:
datalabels: false
extremas: false
color_threshold:
- color: '#b200ff'
value: 10.5
- color: '#e45e65'
value: 7.5
- color: '#ff8000'
value: 5.5
- color: '#e0b400'
value: 2.5
- color: '#0da035'
value: 0
header_actions:
tap_action:
action: more-info
Thanks. The issue is this is a forecast for the future (hourly) so I have a list of values. Can that be fed to a chart?
Possibly, have a look here: Apexcharts and Openweathermap Forecast examples
Hi Tom, would you mind sharing your rest sensor config. I’m trying to create one, but struggling.
This is what I ended up with:
- platform: rest
name: UV Index Sydney
resource: https://uvdata.arpansa.gov.au/xml/uvvalues.xml
headers:
Content-Type: application/xml
value_template: >
{% for location in value_xml.stations.location %}
{% if location['@id'] == 'Sydney' %}
{{ location.index }}
{% endif %}
{% endfor %}
unit_of_measurement: "UV Index"
scan_interval: 600
I use the command line. I would not recommend this.
command_line:
- sensor:
unique_id: c2d041f0-05b6-46e2-af8b-685c7fd0a580
command: "curl -k --silent 'https://uvdata.arpansa.gov.au/xml/'|sed -n '77p'|cut -c 12-14"
availability: "{{ value|is_number}}"
unit_of_measurement: " "
state_class: measurement
If you use it you will have to adjust it for your location. Just visit https://uvdata.arpansa.gov.au/xml/ in your web browser to work out which value you need to adjust the sed/cut commands for. I’m pretty sure I had help with this because I do not remember how it works. There may even have been instructions on the ARPANSA web page at one time, there isn’t now.
You will need to adjust it if a new site is added (they are always sorted alphabetically). I have had to do this once already. I ended up getting the Macquarie island UV index for weeks before I noticed.
I really should do a search for the correct location rather than relying on the position. This is why I don’t recommend it.
Ok, I got some good advice on discord. Try this:
- platform: rest
unique_id: uv_index_sydney
value_template: >
{% if value_json is defined %}
{{ value_json.stations.location | selectattr('name', 'eq', 'syd') | map(attribute='index') | join }}
{% else %}
{{ this.state }}
{% endif %}
scan_interval: 600
It looks like the xml file is dead at the moment and has null data.
Does this happen from time to time?
It’s still being referenced on the ARPANSA website.
Usually not for this long. I’ve sent them an email.
Just fyi they broke it again. SSL issues this time. You can fix it by adding the following to your sensor config:
verify_ssl: false
is helpful for graphing too
I also found this data source which is used by their graph if you want forecast data etc and hour by hour data
https://uvdata.arpansa.gov.au/api/uvlevel/?longitude=145.1&latitude=-37.73&date=2025-09-17
