Hi, I’m trying to create an automation that allows me to set the thermostat to 70 degrees, wait until it reaches that temperature and then set the temperature to 65.
Here’s as far as I’ve gotten after several attempts and reading a few posts:
alias: Thermostat - to 70 then off
description: ""
- platform: event
event_type: ""
condition: []
- service: climate.set_temperature
temperature: 70
entity_id: climate.hallway
- wait_for_trigger:
- platform: state
entity_id:
- climate.hallway
attribute: current_temperature
to: "70"
for:
hours: 0
minutes: 3
seconds: 0
continue_on_timeout: false
temperature: 65
mode: single
I imagine I need to add an action after the wait for trigger state is met but no sure how to do that in the UI?
Just a comment: I would change the wait for trigger “to: 70” → “above: 70” to avoid a situation where the temperature rises beyond 70 without triggering. That or add some other failsafe.
Not an expert in automation, but what is it that makes you think you need something else in there? If it triggers it looks quite similar to one I created in the GUI now as a test.
My attempt at code below via GUI (untested, probably contain errors)
I’m a little confused on what sets the temperature to 70 - does your trigger change the temperature?
I’m trying to use a button on my dashboard to call this automation which is why in my automation I had tried using an action to first set the climate and then wait. Perhaps the part that I have wrong is the triggering of this automation?
Here’s the code from mushroom card I’m using in a grid:
