I just recently found that RP4 won’t start by itself after power outage? I had to turn it on with a Power button, but it’s not an option. How this could be fixed?
As far as I know the only power button for the Pi would be on your power supply. A different power supply would correct that issue.
Yeah. An RPI starts as soon as it gets power, so there might be something specific to you setup you’re not exposing.
I’m using Argon One M.2 case which has a board extension to RP4 with the Power Button… It seems that board has a Jumper and by moving it to other position RP4 will be always On
