How to wire a Sonoff ZBMINI L2 Extreme for UK 2-way Light Switches
As a relative novice, I struggled to work out how to install the Sonoff ZBMINI-L2 switch in my garage with (I think) fairly standard UK 2-way light switch wiring, no neutral.
The Sonoff diagram for my scenario is this one:
Screenshot 2023-05-17 at 09.11.59
The following is my noddy expanded version showing how this was applied in my setup:
I’m sure this is obvious to many but sharing here in case of help for anyone else installing this switch with UK 2-way lights.
Hi there,
Thanks for this. I’ve come to install one but I have a 2 gang switch instead of 2 separate switches
At top of backbox is 2 sets of cables, one on medfly I believe is upstairs landing light and one on right is the hall light which I am trying to add this module to
Top of switch;
Earth → connected to back box
COM → right hand red cable
L2 → left hand red cable
L1 → left hand blue cable
Bottom:
L2; blank
L1; black from right hand cable
COM - yellow from left hand cable
Can you advise me what I need to connect where so I can validate my internal thinking?
Sorry @Ashe - I’m really no expert on this and I can’t advise here.
From my own experience though, I found drawing diagrams really helped.
I’ve tried to set this up myself as well, but am failing.
Can I just clarify - you originally had TWO wires in each of L1/L2 on S2 ? One of each was moved to the Lin/Lout on the Sonoff - these presumably would have been brown and blue with a brown sleeve ?
I don’t seem to have that setup - I have neutral wires in my switch box, and the permanent live is on the COM of S2 (equivalent).
I can get it wired up so the relay controls the light, but not so the switch controls the relay, plus the light is always on regardless of the position of S1, if S2 (or the relay) is on.
I don’t think I can use S1/S2 on the Sonoff unless the switching circuit is separated from the power, which I don’t think it is - one of L1/L2 on my S1 is always live.
When I wire Lin / Lout and measure voltage at the Sonoff S1/S2 I get 240V and 200V respectively. Not sure if that means anything, but as I’ve blown up one relay in the past wiring power across S1/2 I’m keen to avoid doing it again !
There’s going to be some trial and error at some point I think. I am presuming I should be putting the relay at the switch that has the permanent Live wire.
@Lazy_pete - If you have Neutral in your wiring then you may need another device - The ZBMINI L2 is designed for a setup with no neutral. Perhaps a re-think about which device to use?
you are saying you moved the Red cables from Switch L1 and L2 to Sonoff L in and L out. Where do then the grey and Black cables come from which are now in S2 L1 & L2? Are These New cables?
Best regards!
Grey & black are existing cables, and unchanged
But where do then the New Red cables for Lin and Lout come from? I mean you wrote they come from S2 L1 and L2
Just wanted to pop here and say thanks for this! I’ve been holding off doing this for a while with the components on my desk. Finally bit the bullet at this little drawing really helped :smiley:
They weren’t new. I just moved their ends as described in the image.
Okay understood you moved the Red from S2 L1 and L2. But in S2 L1 and L2 are the grey and Black ones which stay unchanged. So where is the solution? Sorry, I simply dont get that haha
Anyone had any luck with this?
I’ve got standard 2 way switch wiring, so would be helpful if anyone can comment on wiring this for the zbmini l2?
Just what I was looking for - thanks for the tip!
I had to comment with another +1 for this diagram. This simplified installation for me immensely after I’d mapped out my current wiring.
Thank you @0rangutan
Glad it was useful!
Love this community and have gained so much from it - great to be able to contribute back.
Thanks!
This diagram is extremely useful and works perfectly for the LIGHT to SWITCH to SWITCH.
Currently struggling with some questionable wiring and SWITCH - Light - SWITCH configuration.
If anyone is searching for a more simple solution, without the need to add a new wire, you can use the following diagram.
It “just” requires that you swap your regular switches with pushbuttons switches.
Phase : Line
Neutre : Neutral
Fil : Wire
Source.
Thanks @PoneyHadess!
Unfortunately, I could only access the marked button and wires. What could I do to achieve a working 2-way switch setup?
Unfortunately, no solution that I can think of in that case.
You’ll have to find a way to gain access to both.
Why is the second switch not accessible?
