hello,
for month I use to write in log file with
notify:
- name: writetofile
platform: file
filename: Pierre_log
since 2024.5 or 6 I get a warning use the new servicenotify.send_message
can you give me a simple example
hello,
notify:
notify.send_message
Hi Pierre, have you seen this? home-assistant.io → integrations → file
the documentation is not clear. I need a small example
Thanks. it works
in configuration.yaml
notify:
in automation
Good you got it solved!
Please take the time to mark your post as the solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so the solution can be helpful to others and prevents that someone else steps in to try to help.
