I have created a float sensor value called “Garage Boiler Heat Output” (in BTUs/hr) that bases its value off of another sensor value called “Modulation” (in %) using an equation.
How can I modify the equation so that “Garage Boiler Heat Output” equals zero if binary_sensor.flame is false, and uses the normal equation when it is true?
Background: 0% modulation = ~17k btu/hr when the boiler is actually running (monitored via binary_sensor.flame). If it is not running, 0% modulation = 0k btu/hr.
It seems to compile, and I have tried some different variants, but value stays at 17,000 when flame is off. (The else 15 was just to try to gain better understanding.)
