How too delete attributes vom device_tracker entity
With the new update of the iOS App I turned on gps location, because there is an annoying bug (see here 196)
I soon switched it off again, because it drains my battery.
Now I still have those lattidude and longitude attributes in my device_tracker entity.
I tried the following without success:
  • comment out/in device tracker in config.yaml to turn the component on and off
  • I deleted the home-assistant_v2.db file
  • I looked for the entity in the core files in .storage and found it in core.restore_state. I deletet those lines. But they reappear.
So how can I get rid of those attributes, because they keep a device home that actually isn’t.
Nevermind, stop home assistant and deleting those lines in core.restore.state worked.
I forgot too change the state too.
EDIT: Unfortunately I still get the gps attributes in my devicetracker. I do not have that option activated for ha on my phone, so this must be old data.
How do I get rid of it?
Deleting it from core.restore_state did not work
I figured it out, it takes the gps coordinates from the config.yaml file
CLOSED
