I’m updating automations using the new purpose-based triggers. In a situation where I check the state of multiple sensors and I want to make the automation resilient to unavailability, what is the best approach?
Lets say I have multiple motion sensors on my driveway. I assign a label ‘driveway’ to the sensors, then check labelled sensors for occupancy. If I understand correctly, a trigger for all sensors unoccupied will fail if one becomes unavailable. So I trigger by checking occupancy (any, unoccupied), then add a condition to check for (occupancy - any, occupied) inside a not block. Is that the optimal approach? Basically a conditional Not-Any is better than All when checking the state of multiple sensors?
In my opinion, the logic for avoiding deadlocks caused by the possibility that a sensor might become unavailable is:
If no sensors are occupied, then the user is absent; if even one sensor is occupied, then the user is present.
If you do the opposite (if all sensors are unoccupied, then the user is absent), a single unreachable sensor would always return a true result.
I don’t think that occupancy sensors can be combined as a group helper. In addition, my goal here is to replace a working and resilient automation with something that takes advantage of the new methodology for automations. The main advantage that I can see is that adding and removing sensors shouldn’t require any updates to the automation, and building in resilience to missing sensors should be easier. If I understand correctly, a sensor group helper would have to be updated when sensors are added.
So I think my current solution, which follows the logic of @Idaho947, is probably the way to do it. The main point is that any trigger that relies on all sensors attaining a specific state is not resilient to unavailability, so better to trigger on any sensor entering that state and then make a conditional check, which in my case is described by ‘not any sensor in group is on’ rather than ‘all sensors in group are off’.
What it is that you are saying doesn’t work?
I have multiple groups of the form:
binary_sensor:
- platform: group
unique_id: sensor_group_living
name: "Sensor Group Living"
device_class: occupancy
entities:
- binary_sensor.entry_door_contact
- binary_sensor.living_main_ir_occupancy
Where I combine various combinations of:
Door contact sensors.
IR presence detectors.
Radar occupancy detectors.
NOTE: I only add contact sensors for doors that are normally closed - so an open door indicates presence.
I think automations have continued to work correctly (need to explicitly test) even when some batteries have died - albeit only with the active sensors (with good batteries) in the group.
Ah, yes, now I see the helper group settings - not sure what I did in the UI to not see this. And yes, the group logic should also work, provided I manually set up the entities.
