I’m studying the capabilities that HomeAssistant has with audio and announcements.
Specifically i’m trying to understand if HA can be a solution to this scenario:
I have multiple rooms with a separated speaker system preinstalled for each room.
Each room has a wifi and a wired network.
I want to install a smart speaker or an audio output module near each speaker system, so with a simple smartphone connected to the same network i can access HA and send an audio file, or a text that will be converted to audio via TTS, to selected outputs (for example only to rooms 2, 3 and 5 out of 8 total rooms).
After some googling i have some doubts on the hardware side: i can use only smart speakers like echo and google, or there are some modules that can do the job without using cloud servicies?
Is Home Assistant useful in this scenario, or there are better solutions without HA involved?
I do this using Chromecast Audio devices. I have several around the house and use TTS to make announcements to them. In some cases, I have predefined announcements “Time to eat”, “Time to go”, etc. I trigger by a zigbee button.
For custom announcements, I have a few input helpers - one to select a speaker / speaker group, and one to input the message - and then a button to push to TTS that message to those speakers.
I’m working on my local voice assistant now. Eventually I’d like to be able to say something like “announce in office it’s time to eat” and have it say the right words in the right room. But I don’t know if that’s technically possible.
Here’s the script I use for announcements. Note it uses Piper for local TTS, but you can use any TTS service you like.
alias: Make an announcement
sequence:
- data: {}
entity_id: media_player.{{speakers}}
action: media_player.turn_on
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- data:
cache: true
media_player_entity_id: media_player.{{speakers}}
message: "{{announcement}}"
entity_id: tts.piper
action: tts.speak
mode: single
icon: mdi:bullhorn-variant-outline
fields:
announcement:
selector:
text: null
description: The announcement to play on the speakers
required: true
speakers:
selector:
text: null
description: The speakers to play the announcement on. Defaults to "whole_house"
default: whole_house
description: Say the announcement given on the specified speakers (default "whole house")
I’m trying to do this too. My challenge is that I am using the universal media player. If I try to send an announcement and it’s not “on” (meaning the speakers for that room aren’t set to that source) it doesn’t work.
How can you get it to send to the entire house and
a) Turn on everything as neede
b) Turn off everything that was off before it started the announcement
c) NOT turn off anything that was playing.
If I send to a media player that is driectly connected to a speaker, it’s no problem.
I’ve read here of some having luck using scenes to save the current state of all the speakers, then make an announcement, then restore the scene to get the speakers to resume the earlier music.
I’ve tried that a few different ways with my Plex / Chromecast Audio setup without luck. I’m hoping I’m just doing something wrong but haven’t had time to dive deep into it.
I just ordered my futureproofhomes Satellite 1 and with the new beta firmware that supports multi room playback with snapcast I’m hoping it might be a replacement for my CCAs
Yeah, I’ve started working with ChatGPT to try and create a script, but I’m just trying to check the state of everything, put them in variables, then restore them. I think I’m close, but there are probably some aspects I’ve not thought of yet.
