i reprogrammed and unpluged back in and the OFFLINE is gone for the card
and i choose logs and i get
INFO Reading configuration /config/esphome/outside.yaml...
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
File "/usr/local/lib/python3.9/dist-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 5] Input/output error: '/dev/ttyUSB0'
File "/usr/local/bin/esphome", line 33, in <module>
sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
File "/esphome/esphome/__main__.py", line 817, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 804, in run_esphome
rc = POST_CONFIG_ACTIONS[args.command](args, config)
File "/esphome/esphome/__main__.py", line 360, in command_logs
return show_logs(config, args, port)
File "/esphome/esphome/__main__.py", line 277, in show_logs
run_miniterm(config, port)
File "/esphome/esphome/__main__.py", line 117, in run_miniterm
with ser:
File "/usr/local/lib/python3.9/dist-packages/serial/serialutil.py", line 565, in __enter__
self.open()
File "/usr/local/lib/python3.9/dist-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 5] could not open port /dev/ttyUSB0: [Errno 5] Input/output error: '/dev/ttyUSB0'
i ended up pulling usb and rebooting HA
now i saw in the one youtube video. you need a Green Bar at top the Red is offline this isnt
but it did connect to my wifi…
can you tell me if its setup correctly… least to get the board up and running… as i wanted to make sure these 2 boards i bought were working before i tried the DHT22
ok so i can view both wroom 32s via the Wifi i only have the 1 usb cable that works to program i have to get another one… i thought it was a usbC like the rasberry pi but i was wrong… i figured i had cables for these devices lol…
so i think i have to hold the boot button down for the wifi…
and the OTA is that part of ESP Home?
so the green bar is not part of latest version you mean? and the clean card you mean where it doesnt say offline right?
least it seems to be working
and how can i make a small little test
like
Print “Hello”
then i wanna change it to
Print “Good bye”
then i wanna try to upload via wifi and see if it will print “Good bye” so i know its truly uploading via wifi
and i not at the computer at mome is the OTA also part of the HACS if its not part of the ESPHome
ill have to look up doing a car repair so i replying in between lol
i appreciate the help so far… least you guys got me up and running…
so here i the wifi upload… but i still wanted to do a test
so Text would say Hello at first… and then “Good Bye” when i change the yaml and upload via WIFI
here is the code. i added that OTA stuff
i did find you cant change the name when doing wifi it buggers up… but is it working 100% as i wanna move on to testing the DHT22 if these 2 modules working they both gave the same report
so i deleted and re made it and chose nodemcu-32s one still cant do GIOP23 or D2 doesnt like it
keeps saying that esp32dev…
gonna reboot HA and re attach things maybe then the nodemcu option works…and if i do GPIO23 that doesnt give error… but the picture is GIOP unless they made the diagram wrong?
ah ok figured as much…
and its working guys… 2 wroom32s with each one having a dht22 i didnt do the resistor for the humidity… its showing humidity without it…
so testing
my next question… can these run without Home Assistant? stand alone doing the same stuff like ha… instead of me needing to code like ardunino
my sister has old furnance… 2 wire version
i wanted to have a screen 2 Buttons up and down with a dht22 and a relay…
so she can set the temp through home assistant or if its off… the wroom32 can run indepent… so is it possible to do it… if so are there examples of people doing it?
oh i also orderd those WEMOS D1 Mini i saw in a video making thermostat… but i having hell of of time the log file is going nuts with with ff:Ee: or what not
i was able to get 2 out of 3 to work… they all act the same … 2 basiclly started to work
maybe that one is no good? the blue light on it keeps flashing after its been supposedly flashed
update:
nothing worked… guess ill return it… i guessing the wroom32 is a better module to get more of those over the mini d1… i liked it cuz it was small
