Howto add a toggle-switch button to a card
Hell everyone,
This is picture of a native entities card with a toggle-switch button. The kind of toggle-switch that is used everywhere in Home Assistant :
Is there an easy way to include such a toggle-switch button in a Tile card, or mushroom template or even bubble-card ?
I must miss something as all my tries end-up with lots of card_mod CSS tweaks. It seems an overkill.
Thanks for your help & ideas
Note that in 2025.3 you can see a similar switch on the Tile card for “toggleable” entities.
post by mistake. sorry
This is the toggle feature in the Tile Card
features:
  - type: toggle
type: tile
features_position: inline
vertical: false
entity: light.pc_lights
That is the new “feature” PR I was waiting for in the Tile card! For some reason I could not see it.
After HA restart it is available and I can have this now.
Huuuuuge button !
You can adjust the size with card_mod
features:
  - type: toggle
type: tile
vertical: false
card_mod:
  style:
    hui-card-features $:
      hui-card-feature $:
        hui-toggle-card-feature $:
          ha-control-switch$: |
            .switch {
              width: 50% !important;
              left: 100px !important;
I was going to ask if someone knows ho to tweak the size. Thanks !
I did this to also change height and keep vertically centered
card_mod:
  style:
      hui-card-feature $:
            .switch {
              height: 70% !important;
              position: absolute;
              top: 50%;
              left: 50%;
              transform: translate(0%,-50%)
I just provided a quick example. Edit away!!!
BTW, is there a place other than the source code to find out which CSS targets to tweak ?
Code Inspector
I am on home assistant 2025.4.2 … and have tried to follow the above to create a sliding on/off card as above … but all I get is
hot
The code I am using (copied from above, and slightly changed is below ) … what am I doing wrong?
features:
  • type: toggle
    type: tile
    vertical: false
    entity: sensor.hotwater_boost
