Hi there! I’m relatively new to Home Assistant and run Hassbian 0.75.2 on a Raspberry Pi. Currently, I’m involved in some development for the ESPixelStick, a DMX LED Strip controller that can also be controlled via mqtt_json
I have a few set up and they work just fine using this type of entry in configuration.yaml
- platform: mqtt_json
state_topic: "esps/2"
command_topic: "esps/2/set"
brightness: true
rgb: true
effect: true
effect_list:
- Solid
- Blink
- Flash
- Chase
- Rainbow
- Fire flicker
- Lightning
- Breathe
Now, most of the effects can be mirrored (start from center) and/or reversed (run the other way round). When clicking on the light, I get a nice popup with a switch, brightness, color and effect controls, but I would also need two checkboxes in there for [x] Mirror and [x] Reverse.
These, in turn, should generate something like "mirror":true
and "reverse":true
in the MQTT JSON string.
Later on, we might also need a speed slider (default: 1000), but this is not currently implemented.
I can’t find out how to do this, do you have any tips for me?
Thanks in advance!
