Hi, I just flashed a Sonoff Touch switch with Tasmota firmware (IP: 192.168.1.80 and client name is sonoff-corr) , and configured it in Home Assistant succesfully…
On your second tasmota sonoff, under MQTT settings change the topic to something other than what the first sonoffs topic is ( for example, “sonoffNEW” ) , unless of course you want everything to switch on and off at the same time.
No matter what I do or what order when I add the second switch in configuration.yaml the first switch does not show up on the Home Assistant
Both Sonoffs work perfectly but I cannot get more than ONE to show up in Hassio at the same time and I have a shit load more I want to flash but I cannot show more than ONE at a time. This is really a PITA.
The second switch always removes the first switch
I got it… i had to add those little minus signs and it worked
my configuration looks like this, but i still do not have the second switch on my home page.
and it is already connected to mqtt server (both of them).
