I bought the new GIEX GX02 Water timer valve and finally got it to work with Home Assistant and ZHA with Quirks, and I wanted to share it with you. The instructions you can find here.
Have a great day
Christian
Have a great day
Christian
Hi!
Nice! You should open a PR here Pull requests · zigpy/zha-device-handlers · GitHub now to add it to HA
Thank you very, very much. I have followed the instructions and all is working well. Only change needed was to drop the leading slash in the quirks directory definition in the configuration.yaml file.
Hello thanks for tutorial,
I’m a newbie en HA, I’m trying to make it work this valve with HA but i have this error:
Enregistreur: homeassistant.setup
Source: setup.py:273
S’est produit pour la première fois: 11:45:27 (1 occurrences)
Dernier enregistrement: 11:45:27
Setup failed for ‘zha’: Invalid config.
and this:
Enregistreur: homeassistant.config
Source: config.py:1324
Invalid config for ‘zha’ at configuration.yaml, line 19: ‘chemin_base de données’ is an invalid option for ‘zha’, check: zha->chemin_base de données, please check the docs
Invalid config for ‘zha’ at configuration.yaml, line 21: ‘activate_quirks’ is an invalid option for ‘zha’, check: zha->activate_quirks, please check the docs
Invalid config for ‘zha’ at configuration.yaml, line 23: ‘chemin_quirks_personnalisé’ is an invalid option for ‘zha’, check: zha->chemin_quirks_personnalisé, please check the docs at
My HA look like this:
default_config:
frontend:
#themes: !include /config/themes/ios-themes/ios-themes.yaml
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
Anyone have an idea where i’m missed ?
