Is there anything I can do to make that sensor functional?
How exactly do I enable the sensor the right way?
(I think I might not have done it properly)
I have 2 of these devices. It seems that whenerver zwave-js starts, it gets the configuration wrong. I have to re-interview the node every time I restart zwave-js-ui. Once it has been re-interviewed, you should see a ‘’[7-32-0-currentValue] Current value’ under Basic V1, which is 255 for motion or 0 for no motion. Then you have to go into Home Assistant and enable the ‘basic’ control, as it is hidden by default. You should then get a number._basic entity. You can then turn this into a binary sensor with
Hi, Just starting with HA and have a number of these devices that are doing almost what this post states. ZWave JS UI now seems to remembering the Current Value under Basic v1. However, the ‘binary _sensor’ entity still doesn’t work. I notice the template is now not apparently receommended as it’s a legacy one. What was yr fix after? Could you advise a template which updates the ‘binary _sensor’ from the Current Value under Basic v1?
