No this installs Hassio in ‘normal’ Docker. Just follow the instructions here:
The script sets up Hassio and it’s supervisor & addons as Docker containers just like your other services.
Great, thanks!
I was able to get a cached version, Works great. Thanks!
Thanks for your excellent guide
I’m in the middle of doing a very similar setup as you:
But I’m debating if I should install docker directly on the Proxmox host and run everything from there or, as you did, create a debian VM and install docker on that.
It seems slightly easier to just run docker directly on Proxmox and skip the hurdles with creating a VM.
On the otherhand i guess you risk screwing up you Proxmox host.
Why did you go for a seperate VM and not run docker directly on proxmox?
If you run Proxmox as your base OS and you need Docker, you should run Docker inside of a VM (Debian or Ubuntu Server). I have tinkered with Docker installed directly on a test Proxmox host install and even in a Proxmox container with apparmor turned off, and I always seemed to have weird random problems. I don’t think Proxmox likes to share resources with other programs like this since it wants to be the main controller.
If your only goal is to run Docker containers, then just install Ubuntu Server or Debian as your base OS and stick with that. Proxmox is not necessary in that case.
Pretty much the reason you said, to prevent screwing up the Proxmox host.
Also now I am in the process of clustering a second NUC. So having the Docker host in a VM means I can migrate it from node to node and use the high availability features.
Sorry for the downtime on the web server… moved hosts and messed something up in the process.
Could you provide me some help? Actually im migrating to laptop, but i think it is not different that much.
I just want to ask, when u install debian on VM thorugh the install did u see connections i mean could you download gui etc? I just saw a dhcp error and had to install minimalstic version
In Proxmox, in your VM settings, make sure VMBR0 is connected as eth0 device for the VM.
I followed all steps and now i have Hassio installed on a VM on Proxmox.
However, i’m not docker expert and i don’t know how to make run homeassistant with option “–net:host”.
I have installed portainer and i can see all running containers in server , but i don’t know how to setup docker to enable this option when restart homeassistant container.
Anyone can help me?
Hi @oakbrad
Actually I’m running on a Intel NUC i3 with 8GB ram with ESXi 6.5 (free version) and Ubuntu Server 18.10 and finally Hassio on it in Docker.
Then I have another VM for Nodered and MotionEye.
What are the advantages of moving from ESXi to Proxmox, from your perspective ?
If you installed HASSIO, that option is already set. You do nothing.
HASSIO is an appliance. Install and leave it alone.
I recently switched from ESXI 6.7 to Proxmox on my NUC. Main reason was that I already had another NUC with Proxmox so I can make a cluster.
Other advantage of Proxmox is that you can make a full backup of a VM. And with this link installing hassos has become super easy.
But ESXI was working fine for me as well.
I’m not that familiar with ESXi or VMWare products, I believe the main difference when I looked was that ESXi only support 2 nodes clustering unless you buy a license (I might be wrong). Proxmox is not limited, they just have paid subscriptions for support, so I went with that.
I have 3 nodes in Proxmox and the only reason I have ever rebooted them since I originally set this up was for a distro upgrade. So I have no complaints, I run a bunch of stuff other than HA.
Just moved from ESXi to Proxmox and seems all fine.
I’ve one VM with 2vCPU (on an Intel NUC with i3-8109U) and 3GB ram with Ubuntu Server 18.10 and Hassio installed in Docker.
Just Hassio with few addons.
The ram is used at 95%, but looking at this I have some doubts.
On the login information, memory usage is at 30%
executing the free command the used value is around 20% while the buff/cache is more than 75%
What is buff/cache used for?
I now have hassio running in Proxmox on my NUC using whiskerz007 one line process, it was so simple.
My question is how can I now copy over a snapshot file I made earlier, Im not sure where to find the homeassistant/backup folder on the NUC
install the samba share addon and access it from your computer.
Some snapshot info: https://gist.github.com/cogneato/24d5a1a0daddec9d048048201170df8b#file-snapshots-md
Thanks guys, that helped, sorted.
I’m wondering why no one is doing
Proxmox LXC Debian/Ubuntu Docker HassIO
